TKBHome New zwave product line
Another company that is going to deliver zwave product.
The first switch is available.
Dual switch including frame and the paddle.
I'm sure that some people will be happy with the build in indicator leds
first con: Logo
Price 55 euro
Specs:
Power rating: 230V, 50 Hz
Wiring: 3-wire system
Maximum loads: all loads up to 6 A
Wireless behaviour: receiver and transmitter if further units are associated
Z-Wave type: slave
Distance: up to 30 m in buildings
Display: 2 blue LEDs show switching status
Interaction: two buttons for switching, inclusion, exclusion and association
Installation: in a pattress box
Power supply: via 230 V power
hkmod25
Re: TKBHome New zwave product line
Post by hkmod25 »
This switch looks for me as simple clone of the ZRM230 from ACT... :-)
Wim2008
Post by Wim2008 »
Has somebody some experience which those zwave devices? Can you read them in Schneider Electric software (before Merten)?
B.R. Wim
eVida SHC
Post by eVida SHC »
Hi everyone, I am an engineer from eVida Smart Home Care, a Z-Wave system distributor & integrator in Singapore.
We have tested the TKB_TZ66-D switch long time ago. One of the problem is that it cannot fit nicely into an external pattress box due to its size (a normal pattress box is too shallow to contain it). You may refer to the attached photo to understand what I mean. For houses with recessed hole for internal pattress box, you need at least a 70mm deep hole for a safe buffer to house the TKB_TZ66-D, and this could lead to extra charges in renovation.
In addition, a neutral wire is required from the ceiling lamp to the switch level. This again is a disadvantage for those with concealed wirings in existing home, unless you won't mind laying an external trunking for routing the neutral wire. Otherwise, it is best to install the TKB_TZ66-D during your house renovation - hence you really have to plan ahead.
However if anyone is interested in a Z-Wave switch panel, eVida Smart Home Care has a Z-Wave touch panel switch, which is priced between 40 to 55 euro, with a selection of single, dual or triple gang touch panel switches. Please email me if you would like to find out more.
eVida Smart Home Care_ TKB_TZ66-D.jpg (10.43 KiB) Viewed 6581 times
Office: +65 6698 6792
Email: hello@evida.com.sg
Web: http://www.eVida.com.sg
WHO is eVida?
We provide smart home and
healthcare monitoring system for remote
monitoring, first of its kind in Asia. Visit
our website for more!
Return to “Z-Wave Forum”
