IPPower HS log entries, I don't understand them?
Forum over de Homeseer IPPower plugin van Rene Klootwijk (DUTCH forum)
Moderator: Rene
olof
Post by olof »
I recently installed the IPPower 9212 & the HS plug-in in order to open/close my gate. It works, mostly, but there are several things I don't understand with the plug-in.
Perhaps anybody can help out?
1. What are all these DEBUG entries in my HS log? Did I configure something wrong? (please find enclosed various screenshots)
2. In order to keep my gate open, I need to re-run the HS Event Gate Open every 10 seconds. But this doesn't seem to happen. It runs again after 1 minute, but I have no idea where to look what the problem could be.
Thanks in advance for any help.
Cheers,
Olof
HS log IPPower entries V2.jpg (126.96 KiB) Viewed 10969 times
IPPower event in HS II.jpg (63.5 KiB) Viewed 10969 times
IPPower event in HS.jpg (54.16 KiB) Viewed 10969 times
IPPower status in HS.jpg (263.11 KiB) Viewed 10969 times
IPPower plug-in config.jpg (94.46 KiB) Viewed 10969 times
IpPower pwd setting.jpg (79.44 KiB) Viewed 10969 times
olof
Re: IPPower HS log entries, I don't understand them?
Post by olof »
Well, now a few days later and I figured some things out....
:oops:
DEBUG entries in my Homeseer log are by choice. Within the IPPower Plugin settings, you can apparently set the level of info detail you want recorded in the HS log.
DEBUG is thus not an error message, but the most detailed level of log entries.
tja....
Olof
The reason the state change is only noticed every 60 seconds is your configured refresh interval of the plugin. This interval can be configured in the plugin configuration page.
olof
Post by olof »
Rene,
Thanks for the reply. But to my, my setting looks like it refreshes every 30 seconds? (see 4th attachment)
Cheers,
Olof
Return to “Homeseer IPPower Plugin Forum”
