rfxmeter/pulse installation
Moderator: b_weijenberg
nawikre
Post by nawikre »
I just bought an rfxmeter with rfxpulse and installed it in Homeseer.
This is what i have done:
In Homerseer go to the RFXcom plugin, then to 'input device'.
Click the 'cl clear' button.
Remove the powerplug from the rfxmeter.
Press the button on the rfxmeter and put the power back on.
A green light starts to flicker.
In the rfxcom plugin click the button 'add' and your rfxmeter will be added.
Now i filled in the following data.
at 'Suffix' i filled in 'kWh'.
at 'Value' i filled in the amount of used kWh that is on the meter in the closet.
at 'Devide by' i filled in nothing, because the meter says 31178 and i used 31178 kWh.
Now i am at a point i have to configure the rfxmeter...
I already resetted the meter to 0
Now it starts to count the kWh...at an interval of 30 seconds
I have read the manual of the rfxmeter and rfxcom i.c.w Homeseer, but i am still missing some data. I cannot find how to configure the rfxmeter so that it can know how to count the pulses of the energymeter in my closet.
The rfxmeter now shows 0,004kWh, the next reading is 0,007kWh, next is 0,009kWh, then 0,0011kWh. In my eyes it does not makes sense. So what can i do to calibrate/configure the rfxmeter?
On the energymeter it says 500imp per kWh.
So if someone can help me with this, i would be very greatfull..
many thanks
Iwan
greetz,
Iwan
b_weijenberg
Re: rfxmeter/pulse installation
Post by b_weijenberg »
try this:
delete the RFXMeter in the RFXCOM - input device screen,
add it again but now with divide by 500
units is kWh
calibration value is the meter value in watts. (so if for example the meter indicates 12345kWh enter 12345000)
nawikre
Post by nawikre »
tried this, but without luck...now when i go to the status page in Homeseer it says 62427kWh. The original kWh is 31202kWh (31202000W)
greetz,
Iwan
b_weijenberg
sorry,
Calibration value = Utility meter counter value * Divide By - RFXMeter value
see also page 34 in the RFXCOM User Guide.pdf
nawikre
Post by nawikre »
Rfxcom user guide only has 25 pages....and the homeseer guide 22 pages? wich user guide do i need then. Can you post a link?
greetz,
Iwan
b_weijenberg
The Homeseer plugin RFXCOM User Guide.pdf is in the Homeseer docs\RFXCOM directory
nawikre
Post by nawikre »
Did not know that there is more info to find there...
found it..
but where can i find the menu 'Device operation' mentioned on page 34??
greetz,
Iwan
b_weijenberg
This is on the homeseer CONTROL PANEL
nawikre
Post by nawikre »
Stupid me....
I found it, put in the neccesary data, but still nothing...it shows now 'counter rolover count 1' . I have no clue on what this means. I was hoping this was a bit easyer.
Any idea's.
greetz,
Iwan
b_weijenberg
did you delete the RFXMeter device and create a new one?
else look at page 34 in the RFXCOM User Guide.pdf
Wim2008
Post by Wim2008 »
Last month I bought also a rfxmeter with rfxpulse and installed it in Homeseer2.
I see the kWh-meter in HS but no change after a few houres of the number.
Here the information of my installing and the line in HS2 of the kWh meter.
What did I wrong? Or did I forgot something?
B.R. Wim
Instelling1ste sensor RFXmeter.jpg (154.1 KiB) Viewed 13017 times
Instelling1ste sensor RFXmeter2.jpg (16.91 KiB) Viewed 13017 times
Wim2008
Post by Wim2008 »
Nobody ?
b_weijenberg
Is de LED on the RFXPulse blinking?
Did you adjust the sensor?
Do you receive an updated counter in RFreceiver?
Wim2008
Post by Wim2008 »
I connected 1 sensor to the rfxmeter and 1 red led is burning continue. No blinking.
I stick the sensor on the glass of the kWh-meter. But what do you mean by adjust the sensor?
How do I receive an updated counter in RFreceiver.
B.R. Wim
b_weijenberg
See chapter 2.5 in the RFXPulse module.pdf
