RFXtrx433 firmware update 67 / 68
Moderator: b_weijenberg
- b_weijenberg
- Forum Moderator
The updated firmware versions 67 and 167 are available on the RFXCOM download page.
FW release 433_67 7-6-2013
- BlindsT0 transmit updated for battery motor.
- BLINDST4 addressing changed
- Transmit sequence number corrected
- LightwaveRF ON decoded
- ARC PIR improved
The most important change is for BlindsT4 - RAEX motor. The unit number is no longer used and the ID has changed from 2 bytes to 3 bytes.
For people that have updated to the new RFXtrx433 Type-2 firmware version 167 they have to use the 3 ID bytes for the RAEX motor. So the application and firmware update must be synchronized!
If a user has already a Raex motor operational he can calculate the new 3 bytes ID as follows:
Byte 1 of the ID is: 0xC2 + unitnummer
Byte 2 and 3 of the ID are the same as used before.
Example:
Unitnumber = 1 and old ID = A2 1C. The new ID becomes C3 A2 1C
- ARC PIR improved
Example:
- b_weijenberg
- Forum Moderator
Re: RFXtrx433 firmware update 67 / 68
FW release 68 is available for download now.
- Lighting5 LWRF Colour commands added
- MDREMOTE LED dimmer added http://www.ultraleds.co.uk/mini-dimmer- ... ximum.html
- Energenie ENER010 https://energenie4u.co.uk/index.php/cat ... ct/ENER010
- Alecto WS1200 added
- Byron SX Chime added
- ELEC4 CM180i current corrected
- ELEC3 CM180 battery indicator corrected
- HomeEasy EU improved (but ARC/Lighting4 degraded with HE EU enabled!)
- Impuls corrected
- Ematronic AC114 improved
- Viking/FineOffset improved
- Impuls corrected
Will the Alecto WS1200 be the first of a series of Alecto units which will be supported or is it using a different protocol compared to the WS3500 for example ?
I have a new RFXcom.
With the old FW. [ 67 ]
Is there some one that will explane to me how i can upgrade this fw??
Please...
Please...
1) download the tool needed to flash your device
http://www.rfxcom.com/Documents/RFXflash.zip
2) download the fw for your device (you have tyype 1 or 2)
rfxcom.com/Documents/RFXtrx433_Type1_fi ... rmware.zip
or
rfxcom.com/Documents/RFXtrx433_Type2_fi ... rmware.zip
Best regards, Walter
or
- b_weijenberg
- Forum Moderator
@Dylan(tje)
please read the RFXtrx User Guide available at http://www.rfxcom.com/Downloads
Can i make the RFXcom broken with a Fw update?
Or is there no thing to be a fread of?
And how do i new what type i have?
The type 1 or the type 2?
I have a firmware update.
Only my protocolls are not enabled.
What i try, the are not to enable
Everytime i will save them they are not going on, the marker is away when i save them.
And then the ui give dissabled.
help me please...
Edit: the RFXCOM s well working in domoticz, after the firmware update?
help me please...
- ScreenShot007.png (193.56 KiB) Viewed 24079 times
- b_weijenberg
- Forum Moderator
BlindT0 will disable all other protocols!!!
Do not select BlindsT0 unles you want to receive the Rollertrol remote to know the remote ID. In all other cases select only the protocols in use.
See chapter 2.4 http://www.rfxcom.com/Documents/RFXtrx% ... 0Guide.pdf
And do not select undec on unless requested by RFXCOM.
A match better...thanks
Only ARC is going of everytime, is that a problem? [ i think yes, this is the protocoll for NEW KaKu, and that is my most used one.. ]
Bud now i have the most protocolls marked
Ps what is the differends between,Type 1 and type 2 ?.
- ScreenShot011.png (152.78 KiB) Viewed 24077 times
- b_weijenberg
- Forum Moderator
Please please RT.M : RFXtrx User Guide!!
See chapter 2.2 for the differences between Type 1 and Type 2
This chapter gives you also the information which protocol to enable for a certain protocol.
You cannot enable all protocols because some will inhibit other protocols or at least reduce the receiver sensitivity for another protocol.
Chapter 2.4 says:
The sensitivity of the receiver part is highly influenced by the number of protocols enabled.
Lesser protocols enabled will make the receiver more sensitive for the enabled protocols.
So for example if you do not have Meiantech sensors do not check this protocol, if you only have old KAKU, check only ARC.
The protocol enabling is only for receive, the transmit protocols are always enabled.
Chapter 2.4 says:
One problem.
I cannot mark the arc, when i save the settings the arc marker is going of.
Is this the reason that i cannot learn a arc reciver?
I have new and old kaku in my house.
I read something in the firmware that there was a better code for the kaku setting [ or i read this in domoticz ]
Is there a option that i read the a arc code.
Because i have a problem with the switches, domoticz change the status in de gui not when i push a kaku.
- ScreenShot012.jpg (107.15 KiB) Viewed 24068 times
What are the changes for Impuls in this release ?
I just bought an Impuls set but it is not working (Yet)
I put the following dip switch setting 1100111100 which should make it M16 but apparently it is not (using RFXcom plugin in HomeSeer)
Nevermind answer took to long
I just update firmware from 55 to 68 and it is working now
p.s. Why is there a version 69 in the download zip but no release notes ? http://www.rfxcom.com/Documents/RFXtrx4 ... rmware.zip
- b_weijenberg
- Forum Moderator
Version 69 is not yet available in home automation software packages.
FW release 433_69 23-10-2013
Siemens SF01 LF959RA50/LF259RB50/LF959RB50 transmit for extractor hood added
home.nl/producten/afzuigkappen/plafondunits/LF959RA50.html
Livolo transmit added http://www.aliexpress.com/store/all-who ... 00715.html
TFA 30.3133 improved
Is there a new update? [ is see a change @ 15-11-2013 ] Firmware 70?
What is new?
Need to update or not?
What is new?
