Problem with interfaces tab in homeseer
Moderator: b_weijenberg
Phaeton
Post by Phaeton »
I get attached problem when trying to use the interface tab. Tried to re-install te plugin, deleted devices with the same Housecode, but no progress. Anybody know how to fix this?
Schermafbeelding 2013-11-09 om 22.09.08.png (214.89 KiB) Viewed 4031 times
groeten,
Re: Problem with interfaces tab in homeseer
I don't know what you try to do here but the error says that the number that is tried in line 498 Item(i) is not available.
There are several ways to fix this. First make sure that garrDevices.Item(13) to (20) have values. Make sure that the array garrDevices have atleast 20 elements. Or put an Try .. Catch.. block around this
Phaeton
Post by Phaeton »
Funny thing is. I dont try anything but opening the interface ;)
Sent from my GT-I9300 using Tapatalk
groeten,
