Buienradar monitor HS3 plugin
Buienradar monitor HS3 plugin van Labium (Dutch allowed forum)
Moderator: labium
labium
Re: buienradar monitor hs3 plugin
Post by labium »
i t will take some time to see which dll's i have to distribute with this dll if you dont run visual studio on your computer
http://msdn.microsoft.com/en-us/library/8kche8ah.aspx
http://msdn.microsoft.com/en-us/library/dd293575.aspx
http://msdn.microsoft.com/en-us/library/dd293565.aspx
labium
Post by labium »
i think but dont know for sure you have to download and install this c++ redistributable.
http://www.microsoft.com/en-us/download ... x?id=40784
vanisher
Post by vanisher »
Net geprobeerd, nee dat is 'm ook niet.
labium
Post by labium »
vanisher
Post by vanisher »
Just tried:
Initializing plug-in(2): BuienRadarGps Instance::Could not load file or assembly 'SplineFormCpp2.dll' or one of its dependencies. The specified module could not be found.0STACK:Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessage(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(MessageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces()
bartbakels
Post by bartbakels »
Still the same issues as well, btw are u running on 32 or 64 bit. Im on 64. I had some issues with jon00 apps also. He needed to rebuild the exe to solve this, had something todo with build settings in C
Regards
Bart
(ON ESXI )on NUC
labium
Re: Buienradar monitor HS3 plugin
Post by labium »
it runs on windows 8.1 64 bit . according to the platform toollset the 2013 version of the c++ redistributable should do it, did You restart the computer ?
i will now try to compile it with the dependencies as in this response is suggested
http://stackoverflow.com/questions/1970 ... o-msvcr100
labium
Post by labium »
i did put the buienradargps on a remote computer with vista 32 bits, i got the same error the slineformcpp.dll or it dependicies couldnt load. but after downloading c++ redistributable for visual studio 13 file version version 12.0.2501.1 it worked.
bartbakels
Labium it works , thnx! . Important is that you install the 86 version even on a 64 bit machine.
However i dont see any errors and do see graphs. The status device still says disconnected
Regards
Bart
(ON ESXI )on NUC
vanisher
Post by vanisher »
Same here!
Graphs but disconnected..
Thx for helping out!
labium
Post by labium »
if you didnt ask anything i wouldnt have learnt anything.
bartbakels
hehe, lol,
but does it work for you, the status device labium?
regards
bart
(ON ESXI )on NUC
esschenk
Post by esschenk »
Hallo,
Ik wilde het script installeren maar mis een aantal files in de zip
alleen de hspi_buienradargps en 4 files in de in de js map zijn aanwezig
Groet
Ed
labium
Post by labium »
this forum is in english please. i think you downloaded the first one not buienradar1.0.0.5.zip
labium
Post by labium »
the status device is green with me, but it is Always green so i dont know if it is a new status or old one , once introduced , i will look in to it.
Return to “Homeseer Buienradar monitor HS3 plugin”
