experts gezocht
Edwin
experts gezocht
Post by Edwin »
I have a problem with my source and know that there are computer experts here who might help :)
the plugs all give back the consumption in real time , but there are only 3 which make a graph, The rest only gives 0:00 in the beginning of the graph charts in the source and nothing else . I got this for months and had many times contact with plug wise especially with Anton.
Who thinks it is the link with home seer and that I should run only the Source.
This I have tried: to turn off the plugin but unfortunately it did not help .
Also a backup sent to plug wise, but Anton could not find anything strange in there .
I use source 2.23 and the latest updates for the plugs .
Does anyone have an idea what to do ? (sorry for my english)
thanks
greetings
edwin
Darwusch
Re: experts gezocht
Post by Darwusch »
Did it work correctly before, or with older versions of the Source?
Edwin
Re: experts gezocht
Post by Edwin »
Darwusch wrote:Did it work correctly before, or with older versions of the Source?
Yes, it did but dont no what version.
Greetings
Edwin
Darwusch
Re: experts gezocht
Post by Darwusch »
Have you checked the logging interval of these appliances?
You can see it in the Module settings.
To go there, right click on a plug, then Properties, then click on the small icon next to "Meter".
There you see the interval. See image.
What does it say?
Edwin
Re: experts gezocht
Post by Edwin »
Darwusch wrote:Have you checked the logging interval of these appliances?
What does it say?
when i do as you told me i dont get the interval window at all .
With none of my modules even the working ones,I have source version 2.23 what version do you have?
greetings
edwin
Darwusch
Re: experts gezocht
Post by Darwusch »
Sure?
Do you not have this button?
I use 2.24 beta but had this button in 2.23 too I think.
Edwin
Re: experts gezocht
Post by Edwin »
Darwusch wrote:Sure?
yes i have that button but when i push it i dont get logging interval to see
plug instel.png (9.44 KiB) Viewed 17945 times
Darwusch
Re: experts gezocht
Post by Darwusch »
Ok, probably mine is different because I changed some other things.
You say that the real time power is shown, so the plugs work (at least partially).
Can you see if the mdb file that the source uses contains history data?
I will look up the location of it later, if you can not find it.
PietjeNL
Re: experts gezocht
Post by PietjeNL »
In the past i had the same problem, but i am unsure how it got solved.
These are the things i tryed after contacting the helpdesk of plugwise
Does the logging start again after u remove the circle from the appliance and then move it back?
So u drag the appliance to the meters section again and then after a minut u drag the meter back on the appliance.
If u hold ctrl and press in the appliance the 000 button it should reset all the data from the circle, maybe that will get it starting again.
What happens if u reset the module and add it again?
Edwin
Re: experts gezocht
Post by Edwin »
Darwusch wrote:Ok, probably mine is different because I changed some other things.
is it c/programfiles/plugwise/plugwisesource/db? theres in my folder an MDB file wich is called "Empty" and 612 kb
cant find any data there.
Edwin
Re: experts gezocht
Post by Edwin »
PietjeNL wrote:In the past i had the same problem, but i am unsure how it got solved.
i will try youre ideas too
thanks for youre help
Darwusch
Re: experts gezocht
Post by Darwusch »
Edwin wrote: is it c/programfiles/plugwise/plugwisesource/db? theres in my folder an MDB file wich is called "Empty" and 612 kb
No, on my PC the DB file is located here:
C:\Users\<Username>\AppData\Local\Plugwise\Source\DB\PlugwiseData.mdb
Then make a copy of the file (because it is in use) and then open that copy.
Look in the tables:
Appliance_Log and Module_Data_Buffer
Is there any data in there?
Because here is the data stored where the Source makes the graphs from.
Edwin
Re: experts gezocht
Post by Edwin »
Look in the tables:
i still use xp so this is not the same.
cant find any other mdb
Darwusch
Re: experts gezocht
Post by Darwusch »
Try this location then:
"Documents And Settings\<user>\Local Settings\Application Data\Plugwise\Source\DB"
Edwin
Re: experts gezocht
Post by Edwin »
Darwusch wrote:Try this location then:
I looked there, the map DB is there but is empty and i switched on hidden files in map options.
Return to “Plugwise Forum”
