ELV MAX! protocol description
Moderator: jrkalf
Re: ELV MAX! protocol description
Postby pbrand » Fri Jan 02, 2015 6:37 pm
The M message is described at the start of the topic in the first item. It also describes where the rf address is.
I have also described the M message at my blog so you could take a look there also (adreamerslair.nl/2014/02/eq-3-max-cube- ... he-m-word/)
All the indivdual bytes are mentioned, so I'm not sure which part is unclear to you?
pbrand
Postby mactoolz » Sat Jan 03, 2015 12:52 am
i have corrected my byte constellation and everything works. The H/M command i have evaluated.
Now I have to evaluate the C/L command. Then i will then give me the send command.
Soon to my problem in general. I have been programming all in a PLC system. The development environment is of 3S Smart Software Solutions. The difficult part is that I can not perform dynamic memory allocation. But it goes anyway.
Maybe I report back later when it comes to the other commands.
Thank you first in advance
MacToolz
mactoolz
Postby mactoolz » Sat Jan 03, 2015 12:12 pm
how can I detect a change in state of a device eg of a window contact.
Thanks
MacToolz
mactoolz
Postby mike7 » Wed Feb 04, 2015 3:22 pm
Found Lock Manual Controls (0x80) command in Homegear wiki. Set payload to 1 or 0 for LOCK or UNLOCK.
mike7
Postby mike7 » Wed Feb 04, 2015 3:24 pm
mactoolz wrote:how can I detect a change in state of a device eg of a window contact.
You have 2 options:
- periodically request the cube
- use RF sniffer
mike7
Postby mactoolz » Sat Mar 28, 2015 8:28 am
Hi
which device would be suitable for this
periodic connection to the max cube does not work. when every second the connection degrades and crashes the cube ...
Mactoolz
mactoolz
Postby mike7 » Sun Mar 29, 2015 9:09 am
mactoolz wrote:Hi
Mactoolz
If you are talking about RF Sniffer, I can suggest you to start here domoticaforum.eu/viewtopic.php?f=66& ... amp;t=7015
I'm using RF22 with arduino https://github.com/matthijskooijman/arduino-max, don't forget to implement the patch domoticaforum.eu/viewtopic.php?f=66& ... =15#p61667
Also you can take a look to FHEM and Homegear
I have no issues with connection to the cube, only one connection can be opened at the same time, on connect you will get response in form of H message. I suggest you to not pull cube very often
mike7
Postby erik_bies » Wed May 27, 2015 1:06 am
You can actually get many updates, even once/second if you really want.
In that case you should send l commands, without breaking the connection.
The Cube will respond with an L response.
If you want the whole message, make sure you properly close the connection before attempting another one. Also don;t have 2 local apps query the cube at the same time as one will close the connection of the other.
erik_bies
Postby mactoolz » Fri Jul 31, 2015 3:30 pm
Hello there,
i'm just back to my project it. How can I recognize the dee Ecotaster been pressed.
thx
Mactoolz
mactoolz
Postby Massi » Thu Aug 06, 2015 3:39 pm
do some test. As far as i can remember, the info is not in the ecoswitch entry, but in the cube entry. Strange..
i never decoded that (not useful for me)
Massi
Postby dmitry-kazakov » Fri Aug 21, 2015 5:55 pm
Hi there. I want to announce an implementation of the MAX! stack and home automation native (not web-based) GUI.
The implementation of the stack is here
http://www.dmitry-kazakov.de/ada/compon ... ube_Client
The stack is driven by a connection handler which can share same thread for many connections and other stacks (e.g. HTTP etc), which is essential for small embedded platforms. Both Windows and Linux are supported. VxWorks would be no problem as well. The software is packaged for Debian and Fedora Linux for i686, x64, ARM. Supported are the commands described above (L, M, H, S, s), including uploading of the thermostat schedule. The license is GM GPL, i.e. you can use and modify the source code.
The GUI is here:
http://www.dmitry-kazakov.de/ada/max_ho ... mation.htm
It is based on GTK 3.8.3 and compatible with higher versions, e.g. GTK 3.10.x. The GUI is packaged for Windows (msi-installer) and Debian/Fedora Linux (deb, rpm packages). The license is GPL.
Improvement and extension suggestions are welcome.
dmitry-kazakov
Postby jesperlykke » Sun Jan 17, 2016 12:04 pm
Hi here...
I am starting to say this, if no one else discovered that :
Nice program, you made here dmitry !
The program is working with wine under Ubuntu 14.04 btw...
Well. I have a quistion, which i was hoping someone here could answer?, which has nothing to do with dmitry's program.
I have made a Raspberry pi, full blown with house automation.
I have a lot things running and working now (Running Domoticz, and some python and Bash scripts along), but i miss a way to control my MAX!Cube / Thermostat's via preferable commandline/scripts.
I use for now, the EQ3 app, and dmitry's program to control my heating.
I got 1 Cube and 4 thermostat+, 1 ecoswitch and 1 windowcontact in our house here in DK.
I can read a lot about protocol's and controlling MAX with openhab, fhem etc... also there are lot's of protocols and api's on github, but it's very hard to understand what exactly to do, to make it work.
Was hoping someone here can tell me a way to do this ??
I have to tell also, that i have been a Linux guy for a lot of year's, so i understand the working of this OS, also i have for several years been "playing" with raspberry pi's, having both my domoticz control, and a diy squeezebox player working for everyday use.
Best. Rgds; Jesper.
Link to a Domoticz thread i created : domoticz.com/forum/viewtopic.php?f=38&a ... amp;t=9138
jesperlykke
Postby MarnixT » Mon Jan 18, 2016 4:19 pm
you're picture of domoticz in an ELV max topic got me triggered. As I just found out Dmitry also provided HTTP automation with the client which allows for integration with Domoticz (e.g. using node-red and/or MQTT).
You did not yet try to run the programs on the PI itself, did you?
when I find the time I would like to start experimenting as well.
jesperlykke wrote:Hi here...
Best. Rgds; Jesper.
MarnixT
Postby jesperlykke » Mon Jan 18, 2016 6:52 pm
Hi !
MarnixT wrote:you're picture of domoticz in an ELV max topic got me triggered. As I just found out Dmitry also provided HTTP automation with the client which allows for integration with Domoticz (e.g. using node-red and/or MQTT).
Thanks for answering... Actually i did not try to install the fine program, which dmitry wrote on my Pi!; as i wrote i installed it without problems on my ubuntu laptop, with the "wine" windows emulator. I did not try to install the Linux native, as i found it much easier to just grap the windows package.
If you look, at button of this reply, you see a picture of a perfect working application :) -I did not try the http stuff yet through, but i am sure it will work.
Anyway, i am looking for a simple way to proceed a command to adjust the valves.
I tried to make som curl/telnet calls, but i cant figure out, what to write, and how.
Here is a pastout of a curl call :
jesper@JesperHP:~$ curl http://192.168.1.127:62910
H:LEQ1325887,115473,0113,00000000,74496c4d,04,32,100112,122e,02,0001
M:00,01,VgIEAQxTb3ZldsOmcmVsc2URSHYCEkpvc2VmaW5lcyB2w6ZyZWxzZRFH6gMSRnJlZGVyaWtzIHbDpnJlbHNlEUgCBARTdHVlEUdJBQUBuHtKRVEwMzA2NjM5DEVjbyBTd2l0Y2ggMQACEUh2TEVRMTMzMDUxMgxTb3ZldsOmcmVsc2UBAhFHSUxFUTEzMzAyMTUEU3R1ZQQCEUfqTEVRMTMzMDM3NhNKb3NlZmluZSdzIHbDpnJlbHNlAgIRSAJMRVExMzMwNDAwE0ZyZWRlcmlrJ3MgdsOmcmVsc2UDAQ==
C:115473,7RFUcwATAf9MRVExMzI1ODg3AQsABEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAsABEAAAAAAAAAAQQAAAAAAAAAAAAAAAAAAAAAAAAAAAGh0dHA6Ly9tYXguZXEtMy5kZTo4MC9jdWJlADAvbG9va3VwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAENFVAAACgADAAAOEENFU1QAAwACAAAcIA==
C:114749,0hFHSQIEEABMRVExMzMwMjE1KiI9CQcYAzAM/wBESFMaRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIUw5FIEUgRSBFIEUgRSBFIEUgRSBFIEUgRD9MbESoUxRFIEUgRSBFIEUgRSBFIEUgRSBEP0xsRKhTFEUgRSBFIEUgRSBFIEUgRSBFIEQ/TGxEqFMURSBFIEUgRSBFIEUgRSBFIEUgRD9MbESoUxRFIEUgRSBFIEUgRSBFIEUgRSBEP0xsRKhTFEUgRSBFIEUgRSBFIEUgRSBFIA==
C:114802,0hFIAgIDEP9MRVExMzMwNDAwKiI9CQcYAzAM/wBESFUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIVQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhUbESoVQVFIEUgRSBFIEUgRSBFIEUgRSBESFRsRKhVBUUgRSBFIEUgRSBFIEUgRSBFIERIVGxEqFUFRSBFIEUgRSBFIEUgRSBFIEUgREhUbESoVQVFIEUgRSBFIEUgRSBFIEUgRSBESFRsRKhVFEUgRSBFIEUgRSBFIEUgRSBFIA==
C:01b87b,EQG4ewUAEg9KRVEwMzA2NjM5
C:114876,0hFIdgIBEP9MRVExMzMwNTEyKiI9CQMYAzAM/wBESERtRHhU/0UgRSBFIEUgRSBFIEUgRSBFIERIRG1EeFT8RSBFIEUgRSBFIEUgRSBFIEUgRD9EbkS1VP5FIEUgRSBFIEUgRSBFIEUgRSBEP0RtRLRU/kUgRSBFIEUgRSBFIEUgRSBFIEQ/RG1EtFT+RSBFIEUgRSBFIEUgRSBFIEUgRD9EbUS0VP5FIEUgRSBFIEUgRSBFIEUgRSBESERtRKhU/EUgRSBFIEUgRSBFIEUgRSBFIA==
C:1147ea,0hFH6gICEP9MRVExMzMwMzc2KiI9CQUYAzAM/wBESFUIRSBFIEUgRSBFIEUgRSBFIEUgRSBFIERIVQhFIEUgRSBFIEUgRSBFIEUgRSBFIEUgREhUbESoVQVFIEUgRSBFIEUgRSBFIEUgRSBESFRsRKhVBUUgRSBFIEUgRSBFIEUgRSBFIERIVGxEqFUFRSBFIEUgRSBFIEUgRSBFIEUgREhUbESoVQVFIEUgRSBFIEUgRSBFIEUgRSBESFRsRKhVFEUgRSBFIEUgRSBFIEUgRSBFIA==
L:CxFHSQkSGA8qAAAACxFIAgkSGAAqAAAABgG4ewkSEAsRSHYJEhgKKgDhAAsRR+oJEhgQKgAAAA==
I don't know howto make executing commands and soo on, and what to write.... I tried different but it dont seems to work!
All i actually need is to set the valves (4pcs), so that i can control the heating with my presence detection... controlling ecoswitch and windowssensor etc... would ofcause just be a nice bonus!
I see, that it might be possible to install another server at my pi, and maybee control it with that? -But i really prefer if possible to have it simple.
So once again i kindly ask, if someone here knows a simple way of archiving that ?
Rgds; Jesper.
jesperlykke
Postby dmitry-kazakov » Sun Mar 27, 2016 9:46 pm
A quick question. Is there an interest in MQTT server for MAX! Home automation? Please mail me at mailbox@dmitry-kazakov.de if you want it the new release.
dmitry-kazakov
PreviousNext
Return to Homematic, FS20, FHT, ESA and ELV
cron
