Bwired Nodejs, MQTT, Websockets Iskra Smartmeter solution
Re: Bwired Nodejs, MQTT, Websockets Iskra Smartmeter solution
Ok check part 2:
Bwired Log Smartmeter data to MYSQL using Nodejs and MQTT
http://blog.bwired.nl/?p=1049
http://www.mijnsmartmeter.nl
mikeyn
Post by mikeyn »
Hi there,
I have the setup as descriped on http://blog.bwired.nl/?p=913 but i get an error when i run smartmeter.js. Invalid number of lines in telegram (14). I assume this has to do that my gasmeter is not connected. Can you give some advise how to solve this?
Received: /ISk5\2MT382-1004
Received:
Received: 0-0:96.1.1(xxxx)
Received: 1-0:1.8.1(02805.714*kWh)
Received: 1-0:1.8.2(03042.136*kWh)
Received: 1-0:2.8.1(00000.000*kWh)
Received: 1-0:2.8.2(00000.001*kWh)
Received: 0-0:96.14.0(0002)
Received: 1-0:1.7.0(0000.35*kW)
Received: 1-0:2.7.0(0000.00*kW)
Received: 0-0:17.0.0(0999.00*kW)
Received: 0-0:96.3.10(1)
Received: 0-0:96.13.1()
Received: 0-0:96.13.0()
Received: !
thanks in advance
regards,
Mike
try to change this one
if (telegram.length === 19)
make it 18, not working then 17 and so on :)
but let it run 30 secs, the firts package received is mostly not valid
mikeyn
Post by mikeyn »
Thanks. I will test it. I like your work very much btw .
mikeyn
Post by mikeyn »
Hi again,
I tried and i found i think the right one only it gives again an error what i do not understand. i even did a full reinstall from scratch.
createClient is deprecated, use connect instead
Starting Smart Meter
Received:
Received: 0-0:96.1.1(5A424556303035313834303830353133)
Received: 1-0:1.8.1(02807.594*kWh)
Received: 1-0:1.8.2(03050.524*kWh)
Received: 1-0:1.7.0(0000.39*kW)
Received: !
/home/pi/smartmeter.js:111
            parseInt(telegram[16].substr(11,2)) +  2000,
TypeError: Cannot read property 'substr' of undefined
    at processTelegram (/home/pi/smartmeter.js:111:34)
    at SerialPort.<anonymous> (/home/pi/smartmeter.js:156:13)
    at SerialPort.emit (events.js:107:17)
    at /home/pi/node_modules/serialport/parsers.js:25:17
    at Array.forEach (native)
    at Object.parser (/home/pi/node_modules/serialport/parsers.js:24:13)
    at Object.SerialPort.opts.dataCallback (/home/pi/node_modules/serialport/serialport.js:181:12)
    at SerialPortFactory.SerialPort._emitData (/home/pi/node_modules/serialport/serialport.js:396:20)
    at afterRead (/home/pi/node_modules/serialport/serialport.js:372:20)
    at /home/pi/node_modules/serialport/serialport.js:388:9
what can this be?
thanks in advance
ok you need to loose a lot more in your code, all what is related to the Gas
put the complete code in as "code" and i will adjust it for you
mikeyn
Post by mikeyn »
Many thanks for this. I am not able to measure gas. I live in a appartment and the gasmeter is quite far from my home in a central room. So that will not be happening soon i think.
Do we need to adjust the other files as well?
here is the code:
serialport = require('serialport'); var mqtt = require('mqtt');
var mclient,
    config,
    SerialPort,
    smartMeter;
mclient = mqtt.createClient(1883, '192.168.178.38'); //set ip of the Rasp or localhost
var net = require('net');
var client = new net.Socket();
function SmartMeter() {
  this.ConsumedPowerRate1 = 0;
  this.ConsumedPowerRate2 = 0;
  this.ProducedPowerRate1 = 0;
  this.ProducedPowerRate2 = 0;
  this.ActualPowerRate = 0;
  this.ActualConsumedPower = 0;
  this.ActualProducedPower = 0;
  this.GasTimestamp = 0;
  this.ConsumedGas = 0;
SmartMeter.prototype.update = function(data) {
    //publish the complete telegram to a different topic for logging to for example a mysql dbase (handled in my next blog)
    mclient.publish('historical/smartmeter/data', JSON.stringify(data));
    if(data.ConsumedPowerRate1 != this.ConsumedPowerRate1) {
        this.ConsumedPowerRate1 = data.ConsumedPowerRate1;
        mclient.publish('smartmeter/consumed_low', data.ConsumedPowerRate1.toString(), {retain: true});
        //console.log(data.ConsumedPowerRate1)
    if(data.ConsumedPowerRate2 != this.ConsumedPowerRate2) {
        this.ConsumedPowerRate2 = data.ConsumedPowerRate2;
        mclient.publish('smartmeter/consumed_high', data.ConsumedPowerRate2.toString(), {retain: true});
        //console.log(data.ConsumedPowerRate2)
    if(data.ProducedPowerRate1 != this.ProducedPowerRate1) {
        this.ProducedPowerRate1 = data.ProducedPowerRate1;
        mclient.publish('smartmeter/produced_low', data.ProducedPowerRate1.toString(), {retain: true});
        //console.log(data.ProducedPowerRate1)
    if(data.ProducedPowerRate2 != this.ProducedPowerRate2) {
        this.ProducedPowerRate2 = data.ProducedPowerRate2;
        mclient.publish('smartmeter/produced_high', data.ProducedPowerRate2.toString(), {retain: true});
        //console.log(data.ProducedPowerRate2)
    if(data.ActualPowerRate != this.ActualPowerRate) {
        //console.log(this.ActualPowerRate);
        if (data.ActualPowerRate == 1) {var new_ActualPowerRate = 'Low'}
        else {var new_ActualPowerRate = 'High'};
        this.ActualPowerRate = data.ActualPowerRate;
        mclient.publish('smartmeter/actual_rate', new_ActualPowerRate, {retain: true});
        //console.log(new_ActualPowerRate);
    if(data.ActualConsumedPower != this.ActualConsumedPower) {
        this.ActualConsumedPower = data.ActualConsumedPower;
        mclient.publish('smartmeter/actual_consumed', data.ActualConsumedPower.toString(), {retain: true});
        console.log(data.ActualConsumedPower)
    if(data.ActualProducedPower != this.ActualProducedPower) {
        this.ActualProducedPower = data.ActualProducedPower;
        mclient.publish('smartmeter/actual_produced', data.ActualProducedPower.toString(), {retain: true});
        //console.log(data.ActualProducedPower)
    if(this.GasTimestamp != data.GasTimestamp) {
        this.ConsumedGas = data.ConsumedGas;
        this.GasTimestamp = data.GasTimestamp;
        mclient.publish('smartmeter/gas', data.ConsumedGas.toString(), {retain: true});
        //console.log(data.ConsumedGas)
function processTelegram(telegram) {
    var smartMeterId,
        consumedPowerRate1,
        consumedPowerRate2,
        actualConsumedPower,
        actualPowerRate,
        producedPowerRate1,
        producedPowerRate2,
        actualProducedPower,
        gasTimestamp,
        consumedGas;
    if(telegram.length === 14) {
        // Process equipment label
        smartMeterId = telegram[0].substr(1);
        // Process consumed power
        consumedPowerRate1 = parseFloat(telegram[3].substr(10,9));
        consumedPowerRate2 = parseFloat(telegram[4].substr(10,9));
        actualConsumedPower = parseFloat(telegram[8].substr(10,9));
        actualPowerRate = parseInt(telegram[7].substr(12,4));
        // Process produced power
        producedPowerRate1 = parseFloat(telegram[5].substr(10,9));
        producedPowerRate2 = parseFloat(telegram[6].substr(10,9));
        actualProducedPower = parseFloat(telegram[9].substr(10,9));
        // Process gas related items
        // Get timestamp last report and convert it to epoch UTC format
        gasTimestamp = new Date(
            parseInt(telegram[16].substr(13,2)) - 1,
            parseInt(telegram[16].substr(15,2)),
            parseInt(telegram[16].substr(17,2)),
            parseInt(telegram[16].substr(19,2)),
            parseInt(telegram[16].substr(21,2))
        gasTimestamp = Math.round(gasTimestamp.getTime() / 1000);
        consumedGas = parseFloat(telegram[17].substr(1,9));
        //console.log('Gas Timestamp: ' + gasTimestamp);
        smartMeter.update({
            ConsumedPowerRate1: consumedPowerRate1,
            ConsumedPowerRate2: consumedPowerRate2,
            ProducedPowerRate1: producedPowerRate1,
            ProducedPowerRate2: producedPowerRate2,
            ActualConsumedPower: actualConsumedPower,
            ActualProducedPower: actualProducedPower,
            ActualPowerRate: actualPowerRate,
            GasTimestamp: gasTimestamp,
            ConsumedGas: consumedGas
    } else {
        console.log('Invalid number of lines in telegram (' +
            telegram.length + ')');
function main() {
    var telegram = [];
    console.log('Starting Smart Meter');
    SerialPort = serialport.SerialPort;
    smartMeter = new SmartMeter();
    serialPort = new SerialPort("/dev/ttyAMA0", {
        baudrate: 9600,
        databits: 7,
        parity: 'even',
        parser: serialport.parsers.readline('\n')
    serialPort.on('data', function(line) {
        console.log('Received: ' + line);
        if(line[0] === '!') {
            processTelegram(telegram);
            telegram.length = 0;
        } else {
            telegram.push(line);
main();
i think this should work
no need for other adjustments i think, lets see
var mclient,
    config,
    SerialPort,
    smartMeter;
    var smartMeterId,
        consumedPowerRate1,
        consumedPowerRate2,
        actualPowerRate,
        producedPowerRate1,
        producedPowerRate2,
        gasTimestamp,
        consumedGas;
        smartMeter.update({
    } else {
function main() {
    var telegram = [];
        baudrate: 9600,
        databits: 7,
        parity: 'even',
        } else {
main();
mikeyn
Post by mikeyn »
Thanks again. making progress now.
I think the code works. i combined the 2 files. I do not know yet how to use upstart or something like that and want to fuocus first to get this running. i copied the webserver.js into the smartmeter.js and this is the output in shell. seems quite ok i guess.
 pi@raspberrypi ~ $ node smartmeter.js
Option log level is not valid. Please refer to the README.
Received:
Received: 1-0:1.8.1(02810.484*kWh)
Received: 1-0:1.8.2(03059.122*kWh)
Received: 1-0:1.7.0(0000.72*kW)
Received: !
0.72
Received:
Received: 1-0:1.8.2(03059.125*kWh)
Received: !
Received:
Received: 1-0:1.8.2(03059.126*kWh)
Received: 1-0:1.7.0(0000.70*kW)
Received: !
0.7
now the folling problem is that my smartmeter.html shows not the data.
i am still missing something but i do not see it.
smartmeter.js:
var url = require('url');
var path = require('path');
var httpd = require('http').createServer(handler),
    io = require('socket.io').listen(httpd),
    fs = require('fs');
httpd.listen(8300);
var client = mqtt.createClient(1883, '192.168.178.38');
io.set('log level', 1);
var consumedValues = new Array();
var tmpValue;
var tmpValue1;
// HTTP server
var MIMETYPES = {
    "html": "text/html",
    "jpeg": "image/jpeg",
    "jpg" : "image/jpeg",
    "png" : "image/png",
    "js"  : "text/javascript",
    "css" : "text/css"};
function handler(req, res) {
  function html404(uri, res){
    console.log("404 not found: " + uri);
    res.writeHead(200, {'Content-Type': 'text/plain'});
    res.write('404 Not Found\n');
    res.end();
  var uri = url.parse(req.url).pathname;
  if(uri != '/'){
    var filename = path.join(process.cwd(), uri);
    fs.exists(filename, function(exists) {
        if(!exists) {
            html404(filename, res);
            return;
        var mimeType = MIMETYPES[path.extname(filename).split(".")[1]];
        res.writeHead(200, {'Content-Type':mimeType});
        var fileStream = fs.createReadStream(filename);
        fileStream.pipe(res);
  } else {
    html404(uri, res);
    return;
  httpd.on('clientError', function (exception, socket) {
  console.log('Client error occurred');
io.sockets.on('connection', function (socket) {
  var clientbb = socket.handshake.address;
  console.log("New connection from " + clientbb.address + ":" + clientbb.port);
  socket.on('subscribe', function (data) {
    console.log('Subscribing to '+data.topic);
    //socket.join(data.topic);
    client.subscribe(data.topic);
client.on('message', function(topic, payload){
    io.sockets.emit('mqtt', {'topic': String(topic),'payload':String(payload) });
    var newPayload = payload;
    switch (topic) { //settings for the graph
        case 'smartmeter/actual_produced':
            if (tmpValue1 == newPayload || newPayload == 0 ) {
                return;
            tmpValue = newPayload;
            newPayload = newPayload - (newPayload * 2); //make produced value negative for chart
            break;
        case 'smartmeter/actual_consumed':
            if (tmpValue == newPayload) {
                return;
            tmpValue1 = newPayload;
            break;
        default:
            return;
    //if (tmpValue != newPayload || tmpValue1 != newPayload) {
        consumedValues.push(newPayload);
        //console.log(consumedValues);
        if (consumedValues.length >= 50) {
            //console.log ('Powervalue shifted');
            consumedValues.shift();
    io.sockets.emit('mqtt', {'topic': "smartmeter/graph",'payload':consumedValues });
var mclient,
    config,
    SerialPort,
    smartMeter;
    var smartMeterId,
        consumedPowerRate1,
        consumedPowerRate2,
        actualPowerRate,
        producedPowerRate1,
        producedPowerRate2,
        gasTimestamp,
        consumedGas;
        smartMeter.update({
    } else {
function main() {
    var telegram = [];
        baudrate: 9600,
        databits: 7,
        parity: 'even',
        } else {
main();
smartmeter.html:
<!DOCTYPE html>
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<script type="text/javascript" src="http://192.168.178.38:8300/node_modules/socket.io/node_modules/socket.io-client/socket.io.js"></script>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.8.3/jquery.min.js"></script>
<script src="http://ajax.googleapis.com/ajax/libs/jqueryui/1.10.3/jquery-ui.min.js"></script>
<script type="text/javascript" src="http://192.168.178.38:8300/js/jquery.sparkline.min.js"></script>
<link href='http://fonts.googleapis.com/css?family=Orbitron:700' rel='stylesheet' type='text/css'>
<link rel="stylesheet" href="styl.css" type="text/css" />
<script type='text/javascript'>
var powerValues = new Array();
var socket = io.connect('http://localhost:8300');
socket.on('connect', function () {
    //$("#sockconn").html("Connected");
        socket.on('mqtt', function (msg) {
            var tp_arr=msg.topic.split("/");
            var d = new Date();
            var now = d.toLocaleTimeString();
            var tp=tp_arr[1];
            switch (tp) {
                case 'graph':
                    $('.hpowerValue').sparkline(msg.payload, {
                        type: 'bar',
                        //zeroAxis: false,
                        barColor: '#ff0000',
                        negBarColor: '#009933',
                        zeroColor: '#009933',
                        width: '200',
                        height: '50',
                    break;
                default:
                    $('#message').html(msg.topic + ', ' + msg.payload + ' at: ' + now);
                    var payloadOld = $('#'.concat(tp)).html();
                    $('#'.concat(tp)).html(msg.payload);
                    if(payloadOld != $('#'.concat(tp)).html())  {
                        $("#".concat(tp)).effect("highlight", { color: "#2C3539" }, 1000);
        socket.on('disconnect', function (msg) {
        //$("#sockconn").html("Disconnected");
    socket.emit('subscribe',{topic:'smartmeter/#'});
</script>
</head>
<body>
<div id="cnt">
    <div style="margin-bottom:5px;">
        <div id="frame">
            <div id="consumed_high" style="font-size:35px;color:#ff3333;"></div>
            <div id="label_lg">Power High Rate counter (kWh)</div>
        </div>
        <div id="frame">
            <div id="actual_consumed"></div>
            <div id="label_lg" style="font-size:18px;">Current Power consuming (kW)</div>
        </div>
        <div id="frame">
            <div id="consumed_low" style="font-size:35px;color:#ff3333;"></div>
            <div id="label_lg">Power Low Rate counter (kWh)</div>
        </div>
        <div id="frame">
            <div id="produced_high" style="font-size:35px;color:#009933;"></div>
            <div id="label_lg">Produced High Rate counter (kWh)</div>
        </div>
        <div id="frame">
            <div id="actual_produced"></div>
            <div id="label_lg" style="font-size:18px;">Current Power producing (kW)</div>
        </div>
        <div id="frame">
            <div id="produced_low" style="font-size:35px;color:#009933;"></div>
            <div id="label_lg">Produced Low Rate counter (kWh)</div>
        </div>
        <div id="frame">
            <div id="gas" style="font-size:35px;;color:#ff3333;"></div>
            <div id="label_lg">Gas Usage counter (m3)</div>
        </div>
        <div id="frame">
            <div id="sockconn" style="font-size:35px"></div>
            <div id="label_lg">Current Usage/Producing graph (kW)</div>
            <div id="graph_lg" class="hpowerValue"></div>
        </div>
        <div id="frame">
            <div id="actual_rate" style="font-size:35px"></div>
            <div id="label_lg">Actual Power Rate</div>
        </div>
        <div id="frame">
            <div style="font-size:15px;color:#999;">Latest MQTT message: <small id="message">no message received</small></div>
        </div>
        </div><br>
    </div>
</div>
</body>
</html>
Ok you need to check if your Mosquitto (mqtt) broker is working... are te topics received?
also you use the newest version MQTT nodejs and when i tried that a while back version i could not get it to work with Mosquitto... not sure if its only my problem...but tried a lot!
i use mqtt
"version": "0.3.11",
It's your problem Pieter ;-) It still works with mosquitto but had some breaking changes, so you need to adapt your code.
mikeyn
Post by mikeyn »
I have to start over. i got everytime npm errors. All different ones. I will do this tomorrow. Thanks
@Rene
i know about the Mqtt changes regarding the connect, but even if i do these it was not working with Mosquitto at that time.
perhaps new Mqtt version solved the problem, havent checked yet.
are you working with Mosquitto en latest MQTT version now?
Thanks Pieter
Yes I do.
mikeyn
Post by mikeyn »
Hi All,
it is been a wile but i picked up this project again. i still not receiving any data on the website. I will explain what i did.
I followed every bit of the instructions on the website. also on the end i created 1 file for the smartmeter and webserverfile.
var mclient,
    config,
    SerialPort,
    smartMeter;
mclient = mqtt.createClient(1883, 'localhost'); //set ip of the Rasp or localhost
    var smartMeterId,
        consumedPowerRate1,
        consumedPowerRate2,
        actualPowerRate,
        producedPowerRate1,
        producedPowerRate2,
        gasTimestamp,
        consumedGas;
        smartMeter.update({
    } else {
function main() {
    var telegram = [];
        baudrate: 9600,
        databits: 7,
        parity: 'even',
        } else {
main();
    fs = require('fs');
httpd.listen(8300);
var client = mqtt.createClient(1883, 'localhost');
var tmpValue;
var tmpValue1;
// HTTP server
var MIMETYPES = {
    res.end();
  if(uri != '/'){
        if(!exists) {
            return;
  } else {
    html404(uri, res);
    return;
                return;
            break;
                return;
            break;
        default:
            return;
and as server.js
    fs = require('fs');
httpd.listen(8300);
var tmpValue;
var tmpValue1;
// HTTP server
var MIMETYPES = {
    res.end();
  if(uri != '/'){
        if(!exists) {
            return;
  } else {
    html404(uri, res);
    return;
                return;
            break;
                return;
            break;
        default:
            return;
the html
<!DOCTYPE html>
<script type="text/javascript" src="http://192.168.2.104:8300/socket.io/socket.io.js"></script>
<script type="text/javascript" src="http://192.168.2.104:8300/js/jquery.sparkline.min.js"></script>
<link rel="stylesheet" href="style.css" type="text/css" />
var socket = io.connect('http://192.168.2.104:8300');
            var d = new Date();
            var tp=tp_arr[1];
            switch (tp) {
                case 'graph':
                        type: 'bar',
                        //zeroAxis: false,
                        width: '200',
                        height: '50',
                    break;
                default:
</script>
</head>
<body>
<div id="cnt">
        <div id="frame">
        </div>
        <div id="frame">
        </div>
        <div id="frame">
        </div>
        <div id="frame">
        </div>
        <div id="frame">
        </div>
        <div id="frame">
        </div>
        <div id="frame">
        </div>
        <div id="frame">
        </div>
        <div id="frame">
        </div>
        <div id="frame">
        </div>
        </div><br>
    </div>
</div>
</body>
</html>
The output on the site is still blank.
the node file gives some errors but after googling i found out that it is not an issue only it would be better to upgrade the files.
The files are working because when i load the website i get the line "New connection from undefined:undefined"
after some digging and trying to get aquainted with nodeJS and the rest i tried to debug the file on the socket.io. maybe it gives some information for you to help out if possible
I really like to work with this and tried a lot by myself but i can't figure it out. (sorry for that)
Can you help me?
Return to “Bwired Forum”
