Toon app: Afvalwijzer
michel30
Post by michel30 »
Is it also possible to add the following URL https://www.rd4info.nl/NSI/Burger/aspx/ ... ublic.aspx
michel30 wrote:Is it also possible to add the following URL https://www.rd4info.nl/NSI/Burger/aspx/ ... ublic.aspx
The site is using https, meaning you will have to use wget and a cron job to retrieve the data regularly.
Unfortunately rd4info is not providing a standard calendar file but I can scrape the data from the http page source.
I am a bit hesitant to give a due date right now but it is on my list.
Regardz,
the old mod for the thermostat app did not look good on the newer firmware 4.x versions.
I made this small tweak to make it firmware 4 compatible. I can't put the temperature any higher without making much more invasive changes in the app.
No changes were needed for the Belgian icons, that is handled in the wastecollection app itself.
The attachment contains the full thermostat app for version 4.4.21 but only two files have been changed: ThermostatApp.qml and ThermostatSidepanel.qml.
All code changes are marked between the lines 'waste display start' and 'waste display end'.
Note: the icon will show only 6 minutes after restart of the gui and will be updated daily at 18.01 to show the icon for the next day
Summarizing:
- use the earlier posted version 1.2 of the mod for firmware version 3.7.9 (manually apply to other 3.x versions)
- use this version 1.3 on firmware 4.4.21 (manually apply to other 4.x versions)
both are compatible with any recent version of the wastecollection app.
The screenshot below shows the icon twice: once on the tile (which you don't need with this mod) and one via the thermostat mod.
wastecollection_thermostat_mod_v1.3_(fw4.4.21).zip
(163.69 KiB) Downloaded 615 times
Waste collection v2.2. is available from the toonstore. Please upgrade the toonstore to 0.9.5 first.
Matt88
Post by Matt88 »
Thanks for the hard work but it seems that Cyclus is not working in V2.2. Tried multiple adresses in our region but no data is showing up in the tile. Can someone confirm/check this? (Zip 2805)
makkie2002
Post by makkie2002 »
Thanks Toonz ... you made the first Belgians happy !
makkie2002 wrote:Thanks Toonz ... you made the first Belgians happy !
And you Belgians made us happy as well today, although you scared us quite a bit in the European hockey final :)
Matt88 wrote:Thanks for the hard work but it seems that Cyclus is not working in V2.2. Tried multiple adresses in our region but no data is showing up in the tile. Can someone confirm/check this? (Zip 2805)
Hi Matt88,
The waste collection app is reading the file '/root/waste/waste_calendar.ics' to display the waste collection dates for Cyclus NV.
As this provider is using 'https' which is not supported by Toon, a separate method of retrieving this .ics file is needed.
A 'how-to' to get the calendar file from Cyclusnv is posted by Marcelr earlier:
domoticaforum.eu/viewtopic.php?f=87& ... 235#p82536
Just checking whether you have done this and maybe you can check if the file '/root/waste/waste_calendar.ics' exists.
Matt88
Post by Matt88 »
Thanks a lot Toonz, downloading the ics file and creating the '/root/waste/waste_calendar.ics' location did the trick.
georon
Post by georon »
Thanks for all the work you put in this app.
I tried to clone the app, so I can run it twice (living at the border between NL and BE :) ) but that failed miserably.
It will not load the 2nd app :|
While I was at it, I was introducing the ICS for Limburg.NET (BE), they use a standard ICS (example: http://www.limburg.net/ics/afvalkalender/72030/223/10/0)
Will try another day :)
You cannot simply clone the app and run it twice. Second one needs to have a unique folder name and corresponding app file names. Can be done of course but is a bit of work
Regardz,
georon
Post by georon »
Toonz wrote:You cannot simply clone the app and run it twice. Second one needs to have a unique folder name and corresponding app file names. Can be done of course but is a bit of work
I know, :)
Will figure it out eventually
just to be sure: are you implementing the limburg.net calendar yourself or do you want me to do it? I just had a look and it can be easily implemented in the app.
P.S. about running it twice: you will also need to change all temporary files names with dates, icon names to show etc etc
georon
Post by georon »
If you would like to implement the Limburg.NET code, that would be great. :D
If not, I will be bold enough to do it myself, but merging the code would be a hassle.
Post by TheHogNL »
Graag nog even toevoegen aan :
function wasteTypeMijnafvalwijzer(shortName)
De volgende cases:
case "grofvuil": return 8;
case "tuinafval": return 4;
case "papier": return 2;
Bij mijzelf natuurlijk al gedaan maar zodat straks ook anderen hier van kunnen profiteren :)
