Toon app: Afvalwijzer
madpatrick
Re: Toon app: Afvalwijzer
Post by madpatrick »
Hi Toonz,
I tried to update the app today to 3.5, but after restart it was still 3.4 (tried it 3 times)
After deleting version 3.4 and installing version 3.5 it was correct.
Only now the waste.txt is not working any more.
I'm getting dates that are not in my list. The dates are totally different.
Also the same for the icons directory.
I've placed the waste.txt and icon directory on my webserver and did not change anything before the update.
what can be the problem ?
EDIT
I've found the problem
I did not use www in the link (http://domain.nl instead of http://www.domain.nl)
atlantica wrote:
Toonz wrote:I've integrated the google agenda in thunderbird true the Lightning addin... Mabe this is also a solution for the Afvalwijzer app?
http://mzl.la/1BsOAbb
Doesn't help me either. Exporting the Google Calendar in an ICS file will work but that must be done on your PC/Mac. Not ideal.
maikelvds
Post by maikelvds »
Toonz wrote:
msv wrote:Hello Toonz,
Thanks for the update did you implememt my provider https://www.circulus-berkel.nl/afvalkalender/ My zipcode is 7433SN, 4 this is an ICS file.
Done, will be in 3.1......
Configure as waste provider '20'. You will need to manually copy the ICS file to Toon as '/root/waste/waste_calendar.ics' once a year.
N.B Showing the description "Glas, Papier and BEST " just as "Papier" for the time being (otherwise need to design a new icon for this category)
Hi Toonz,
First of all, what a great app. TerrorSource rooted my toon a few weeks ago, i'm impressed of the possibilities you guys make.
I have waste collector Circules Berkel. I downloaded the .ics file and put it in Toon like:
/root/waste/waste_calender.ics
I had to create the 'waste' directory by myself.
Is there more to do to make it work?
Thanks a lot!
maikelvds wrote:First of all, what a great app. I have waste collector Circules Berkel. I downloaded the .ics file and put it in Toon like:
Almost there, you need to tell the app which provider you have.
Add the Afvalwijzer tile to your homescreen.
Click on the tile to show the screen with upcoming collection dates.
Press 'Instellingen' in the top right corner.
Enter value 20 in the field afvalverwerker (Circulus Berkel).
Press 'Opslaan'.
That should do the trick
maikelvds
Post by maikelvds »
Press 'Opslaan'.
And what if that is not working?
Also delete the app and install again but no result. Don't have to change postcode or something right?
When I check the ics file it is looking OK, a lot of info, after and numbers..
maikelvds wrote: I downloaded the .ics file and put it in Toon like:
I should have spotted this earlier: you have a typo in the filename, should be:
maikelvds
Post by maikelvds »
Aha, there is the mistake! I'm gonna check it asap!
glsf91
Post by glsf91 »
If you are getting bored:
My old request :D :
It should be nice if a parameter can be added to every line of the datafile which tells when the icon must be displayed. For example -6 is 6 hours before midnight (so day before at 18:00) and +6 is 6:00 at the day itself. Problem is that for the wastebin I want the icon the day before, hours can be changed on Settings screen. But for other dates I want the icon on the specific date, so not the day before. Now it also appears at the day before.
Is still on my todo list, has quite some impact.
Also need to change the thermostat mods....
Patience, it will come.....
maikelvds
Post by maikelvds »
That was the mistake! It is working, thanks for your help!
Vibestar
Post by Vibestar »
Some icons.....
- Metal
- Wedding
- Wedding (gender neutral ;) )
- Library (return books)
- Birthday
If there are any other requests :D
Icons.zip
(29.05 KiB) Downloaded 424 times
haha great icons, just can't figure out the 'metal' one, probably my age.... :D
michel30
Post by michel30 »
@Vibestar
Could you also build this one: https://www.nieuwsblad.be/cnt/dmf20170308_02770682
This is an BEST tas for RD4 maybe TOONZ can build this in for RD4?
Sure, will do if there is a nice icon :-) :-)
Hi, I just finished the change to allow special extra dates to show on calendar days only.
Will create a BEST tas icon based on the original from rd4 (boring but familiar):
