Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Yesterday I updatet my rooted Toon with the newest ver of afvalkalender, and now I only A blank symbol.
Any idee ?
Kind regards,
Erik
Any idee ?
Kind regards,
Erik
Sometimes you need to click on the tile, click on 'instellingen' en press 'opslaan' to force the retrieval of the data after a restart. Does that help?
For me that is the only way to get the data, it doesn't do it automatically.
Is there a reason to not do it on startup automatically?
Toon1 running firmware 5.33.9 (rooted)
It is supposed to startup automatically.
Is on my todo list to fix but had other priorities lately.
Once you see the data it is automatically refreshed daily.
Ok thanks for explaining I was expecting for it to work that way, but it didn't.
Thought it must have been a bug.
Nop, Nottingham workshop. Stars blank
Could it be that it has something to do that I have to put a space or 0 (or anything) in the field Straatnr(BE) ? I can't completely empty
will be in 4.11 in the new few daysArcidodo wrote:@toonz i edit the your app to add "oud papier" support for Omrin can you add it to the production version?
//read oudpapier entries i = aNode.indexOf("Oud Papier en Karton"); m = aNode.indexOf("dates", i); for (k = 1; k < 13; k++) { monthStr = ("00" + k).slice(-2); i = aNode.indexOf('"' + k + '"', m); n = aNode.indexOf("[", i); m = aNode.indexOf("]", i); var monthDates = aNode.substring(n + 1, m).split(','); //get array for the month for (l = 0; l < monthDates.length; l++) { omrinAfvalbeheerDates.push(omrinYear + "-" + monthStr + "-" + monthDates[l].replace(/['"]+/g, '') + ",2"); //oudpapier } }
version 4.11 has been published on ToonStore.
It contains a bugfix for the issue that waste calendars are not read after rebooting the gui (bug was introduced in version 4.9 I believe).
Waste data will be read 20 seconds after initialising the app on a Toon 2 (60 seconds for a Toon 1), to allow the gui to startup completely.
Changelog4.11
- added 'oud papier' to the Omrin provider (thanks Arcidodo)
- added an option to create an ICS file for use in the calendar app (based on collected waste data from any provider)
(add calendar: "file:///var/volatile/tmp/wasteDates.ics" to the userSettings.json file in the calender app)
- cosmetic changes to the config screen
- fixed the bug preventing reading waste calenders at startup
Changelog4.11
Hi Toonz,
I have an error since yesterday for my waste collector HVC, see attached screenshot and below the contents of the ICS file that I downloaded from the HVC website, I hope this helps in fixing the error, it also happens in the new version:
BEGIN:VCALENDAR
VERSION:2.0
PRODID:inzamelkalender.hvcgroep.nl_ophalen
X-WR-CALNAME:Inzamelkalender HVC
X-PUBLISHED-TTL:P1W
BEGIN:VEVENT
UID:5c3df6ccb8435
DTSTART;VALUE=DATE:20190206
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190207
SUMMARY:Restafval
CLASS:PUBLIC
DESCRIPTION:Restafval
X-MICROSOFT-CDO-ALLDAYEVENT:TRUE
DTSTAMP:20190115T160548Z
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Restafval wordt opgehaald
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb84ad
DTSTART;VALUE=DATE:20190306
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190307
SUMMARY:Restafval
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb850d
DTSTART;VALUE=DATE:20190116
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190117
SUMMARY:Gft & etensresten
CLASS:PUBLIC
DESCRIPTION:Gft & etensresten
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Gft & etensresten wordt opgehaald
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb8569
DTSTART;VALUE=DATE:20190130
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190131
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb85c6
DTSTART;VALUE=DATE:20190213
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190214
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb8623
DTSTART;VALUE=DATE:20190227
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190228
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb8684
DTSTART;VALUE=DATE:20190313
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190314
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb86e0
DTSTART;VALUE=DATE:20190123
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190124
SUMMARY:Plastic\, blik & drinkpakken
CLASS:PUBLIC
DESCRIPTION:Plastic\, blik & drinkpakken
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Plastic\, blik & drinkpakken wordt opgehaald
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb873b
DTSTART;VALUE=DATE:20190220
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190221
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb8797
DTSTART;VALUE=DATE:20190209
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190210
SUMMARY:Papier en karton
CLASS:PUBLIC
DESCRIPTION:Papier en karton
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
DESCRIPTION:Papier en karton wordt opgehaald
END:VALARM
END:VEVENT
BEGIN:VEVENT
UID:5c3df6ccb87f5
DTSTART;VALUE=DATE:20190309
SEQUENCE:0
TRANSP:OPAQUE
DTEND;VALUE=DATE:20190310
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT12H
ACTION:DISPLAY
END:VALARM
END:VEVENT
END:VCALENDAR
- Error Afvalwijzer.png (107.77 KiB) Viewed 7402 times
I see the same (HVC as well)
will have a look tonight, not a big deal (will be version 4.12)
My problem (not shownieuws anything after update) corrected itself with the first wast collectief day. Everything is back
Hey Toonz,
Alphen aan den RIjn provider 23 seems to be broken.
the url is still working if I try this on a browser.
Could there be something wrong with te SSL setting?
Regards
David
David
