Toon for Android
Re: Toon for Android
0.5.6 is released to Alpha.
Solved issues in this release:
https://github.com/fabianblom/Toon-Andr ... ne%3A0.5.4
Bugfix: When starting app, the correct mode button wasn't selected
Bugfix: Fix toast message when setting stuff (Fixes fabianblom#13)
Bugfix: IllegalFormatConversionException on formatting string
Bugfix: change layout so it works better on lower resolution devices (fixes fabianblom#24)
Bugfix: Next program text contained "\n" text
Bugfix: Use CurrentUsageInfo for power and gas usage instead of DeviceInfo (fixes fabianblom#8)
Bugfix: Get next set point (fixes fabianblom#6)
Enhancement: Auto refresh & pull down to refresh
Enhancement: Change layout to resemble o.g. Toon app
Enhancement: Add support for when no program is used
Enhancement: Add setting to choose between next program or next temp
Enhancement: Set power usage meter relative to average usage
Enhancement: Add extra setting to change temperature by 1 degree
Enhancement: Only 1 decimal after the comma (Solves fabianblom#14)
Enhancement: Provide feedback when using the refresh button (Solves fabianblom#15)
Enhancement: Use burner info (only on OpenTherm?) to show flame
Enhancement: Change mode buttons to resemble the Toon buttons
You made good progress. My compliments. Working much better now.RoadXY wrote:0.5.6 is released to Alpha.
Thanks guys!
Now bring them bugs all I can iron these out before the Beta users get the update.
Let's work towards an stable app so it's available for everyone.
- Administrator
I'm still on 0.5.2 and the Play Store doesn't show an update for me.
Because PlayStore is the Beta channel
This version is available for the alpha testers
Not true. I got the alpha version through playstore._Arjen_ wrote:Because PlayStore is the Beta channel
You have to register as alpha tester first. See previous messages.
Yup you're rightglsf91 wrote:Not true. I got the alpha version through playstore._Arjen_ wrote:Because PlayStore is the Beta channel
Just forgot that part haha
I am registered as alpha tester but only get 0.5.2 from the play store
Can't see any updates either ...
I've double-checked but 0.5.6 is really in Alpha.
0.5.2 is in beta
0.5.2 is in beta
I received 0.5.6 yesterday through playstore as an update.
Ive install it yesterday from the Play Store.
