App ideas / feature requests
- Member
Re: App ideas / feature requests
All my wishes have come true with the new TOON_IP_ADDRESS/Mobile access. I am a happy man
- Advanced Member
I am glad you are happy. I have just made a new mod to kevel the solar today and the production today (number of bars activated) and some textual changes to even improve it more.Arnout2000 wrote:All my wishes have come true with the new TOON_IP_ADDRESS/Mobile access. I am a happy man
- Advanced Member
We even managed to get your smart plugs into toon.
- Member
What do you mean with that?
By the way, on the mobile access screen, how should I interpret the values of:
Elektra productie nu
and
Elektra productie vandaag?
and
Thought it was a bit confusing too, and changed it myself into this:Arnout2000 wrote:
and
Ron.
- Member
That is a much better description
Which file should I modify to change the explanations myself?
You can modify the index.html in /qmf/www/mobile
(starting at line 320 <div class="usage-title">Elektra teruglevering nu</div> and further down is the rest)
Ron.
Ron.
- Advanced Member
If you have smart plugs connected to your Toon (fibaro or neocoolcam) , they will show up in the app also. You can switch the from the app and see the power status of the sockets.Arnout2000 wrote:What do you mean with that?
and
We indeed had some conversation of the text on the app for "productie" of "teruglevering" wat hetzelfde is. Omdat de toon origineel in de grafieken op de toon "productie" hanteerd is daarvoor voor gekozen.
- Member
Found them. Nice!
- 20DA569D-6B53-48F0-B45C-A21F69335638.png (87.39 KiB) Viewed 10056 times
- Advanced Member
You can also switch them from the app. I do not have them myself so if you find anything that doesn’t work, please let me know. Full scale of the bars is 2500 watt (max of fibaro plugs). Maximum of plugs displayed is 12.Arnout2000 wrote:Found them. Nice!
Thanks Oepi-loepi for the enhancements in the mobile app. I tried to check everything on mobile phone and after on my computer. On phone it's possible to go to the different pages, but on the browser on computer it only works to change the pages in the address bar from #main to #consum or #solar. Is there a possibility to make it easily working in a not mobile webbrowser?
I see Zon Huidig and Zon Vandaag are down Teruglevering Huidig and Teruglevering Vandaag. Am I right it's more logical to display this the other way around? So first Zon Huidig, Zon Vandaag and then Teruglevering Huidig and Teruglevering Vandaag. Again, it's just a brainwave.
Keep up the good work!
you can swipe in the browser as well, make a swipe movement with the left mouse button pressed
You can swipe to the next page with your mouse (left click and hold and swipe)Edgar wrote:Thanks Oepi-loepi for the enhancements in the mobile app. I tried to check everything on mobile phone and after on my computer. On phone it's possible to go to the different pages, but on the browser on computer it only works to change the pages in the address bar from #main to #consum or #solar. Is there a possibility to make it easily working in a not mobile webbrowser?
Ron.
Super thanks, I can swipe indeed
- Advanced Member
new release of the /mobile app 1.0.24
smoke detectors changed, names added
1.0.23
smoke detectors added
1.0.23
