Toon app: Afvalwijzer
djgodlike
Re: Toon app: Afvalwijzer
Post by djgodlike »
Toonz wrote:This is the time of the year indeed when cities change their IT contracts with waste companies.
Usually a busy period for me :-).
With the new setup of the app I can just change individual wasteprovider scripts when needed without the need for an app releases each time.
And luckily for you prezero.nl was added recently as well :-).
Just hoping they use the same waste descriptions as in other cities, there is no standardisation of these descriptions across NL unfortunately.
Kind regardz,
Toonz,
Thanks for your reply! And it works indeed! Thanks, also from the wife :D
Krisrock
Post by Krisrock »
Hallo,
Is het mogelijk om deze site toe te voegen aan de afval kalender?
https://www.eemsdelta.nl/mijn-afvalkalender
Postcode:9934
Gr Kris
Krisrock wrote:Hallo,
Gr Kris
Zekers wel, net even toegevoegd. Je kan nu provider 45 kiezen in het instellingen scherm en je postcode/huisnummer invullen.
N.B. De Toon gui zal automatisch herstarten na het ophalen van de nieuwe plugin.
Gr. Toonz
Krisrock
Post by Krisrock »
Gr Kris
Gr. Toonz
Super bedankt Toonz!
gegevens al ingevuld nu wachten dat hij de gegevens heeft opgehaald
jnieuw
Post by jnieuw »
Hi @Toonz,
Just installed 5.2 and could you make it possible to disable the new feature:
version 5.2 is available in the ToonStore.
Changelog:
- the tile shows the next three collection dates in dim state if no waste is collected that day.
If waste is collected then only the waste icon is shown.
In the previous version the tile was empty in dim state if no waste is collected
I preferred the "old" way, now my Toon looks so full when in dim state.
Also I found a problem that not using any provider (previously 0) and only using your own data is not possible anymore.
Thanks!
Hi jnieuw,
good catch for provider "0".
I just added provider "0" as new plugin and also modified the code in the app to handle that properly.
Just wait till the app version 5.3 is available in the ToonStore. Upgrade to 5.3 and select provider "0" in the app settings.
No need to upgrade the app for other users.
With regards to the tile in dim state: why don't you show the collection icons then in the thermostat panel (is a setting in 'instellingen' screen).
In that case you do not need the tile and can use the tile position for another app.
Kind regardz,
jnieuw
Post by jnieuw »
Toonz wrote:Hi jnieuw,
Kind regardz,
Hi Toonz,
Thank you for your reply. The icon in the thermostat panel was always a bit too small and I liked that it was possible to see the upcoming events when I touched the screen.
you can make the following change for now in the file /qmf/qml/apps/wastecollection/WastecollectionTile.qml :
replace the 7 lines :
       		visible: dimState ? (!app.wasteIconShow && !app.wasteIcon2Show) : true  // only show in non-dim if no icons are shown
with
       	visible: !dimState
to go back to the original behaviour
4nuts
Post by 4nuts »
4nuts wrote:Great app ,I use it with waste collector : 1
This entry was missing in wastecollectionProvider.js.
case "papiercont": return 2;
Now it shows : Papier/Karton :)
After updating to 5.3 see the entry is missing , can you add it ?
that's not in the app but in a separate plugin which I just updated online.
The new plugin will be automatically downloaded within a day or directly if you go to the settings screen of the app.
Kind regardz,
4nuts
Post by 4nuts »
Toonz wrote:that's not in the app but in a separate plugin which I just updated online.
Kind regardz,
Sorry you are right after updating to v5.5 everyting is showing as it should, even the " Pinetree" is showing.
Regards 4nuts.
4nuts
Post by 4nuts »
Kind regardz,
Regards 4nuts.
My Toon keeps rebooting after upgrade to 5.5 when I select waste provider 1.
Is it because today 12-01 we have pinetree and GFT on the same day ?
When set it to waste provider 0 it stops rebooting.
I will check tomorrow when I will set it back to wastecollector 1.
Can I check something why it is rebooting ?
Kind regardz,
Regards 4nuts.
There have been a few updates recently for waste provider 1 regarding the new Kerstbomen category and one new waste description.
So, you should have had 2 reboots for provider 1 at maximum
4nuts
Post by 4nuts »
It keeps rebooting and it looks like the waste list is not filled.
4nuts wrote:It keeps rebooting and it looks like the waste list is not filled.
I guess something goes wrong with the download of the script.
Can you check the content of this file on your Toon: /qmf/qml/apps/wastecollection/wastecollectionProvider.js ?
It should have the same content as the script on github for provider 1: https://raw.githubusercontent.com/ToonS ... vider_1.js
Kind regardz,
