Rooting a Toon in Spain: SOS!
Fran
Re: Rooting a Toon in Spain: SOS!
Post by Fran »
Buenas tardes
Yo también instalé el toon con viesgo, pasé a Repsol y funcionó hasta hace no mucho.
Pero ahora se ha quedado "actualizando" y no me deja hacer nada.
Sabéis que problema puede haber?? Alguna solución??
as far as I know Viesgo has stopped the support for Toon. Subscription features are not available anymore.
castellbi
Post by castellbi »
Hola
A mi me pasa lo mismo, me lo instalaron los de Viesgo pero hace unos meses que ha dejado de funcionar, solo sale la hora y la temperatura. Me interesaba porque veia el consumo y lo que estaban captando las placas, sabeis si hay alguna manera o alguna app que se pueda seguir viendo o como hacerlo con esta "tablet"
saludos
EDIT Moderator: please post in English at this forum. Google Translate:
Hello The same thing happens to me, the Viesgo people installed it but a few months ago it stopped working, only the time and the temperature come out. I was interested because I saw the consumption and what the plates were capturing, you know if there is a way or an app that can continue to be seen or how to do it with this "tablet" Best regards
The only option to get the subscription features back is to root your Toon (see guides elsewhere).
However, you might run into troubles there because the VPN server of Viesgo is probably offline, looking at the multiple messages from spain that routing doesn't work.
Our firends in Belgium have the same issue but they could root and activate the Toon by rerouting the traffic from the Belgium (electrabel) server to the eneco server in NL which is still active. Not sure of the exact url of the Viesgo vpn server but you will see this during the rooting process
Google translate of the last post of his topic: https://toonforum.nl/d/822-activeren-bi ... op-boxx/19
¡Finalmente lo hice! Tráfico de Internet redirigido a vpn.eneco.toon.eu a través de adguard home. Y el botón salió ¡Gracias a todos por la ayuda y las sugerencias!
El_perry
Post by El_perry »
Hello, good afternoon, colleagues.
I have had a family problem, and now I have time for myself.
I'm still on the topic of rooting the toon.
But I still don't know how to do it, my fear is breaking the toon.
That's why I read and read how to root but my computer science level is terrible.
Wouldn't there be a step-by-step manual with images for people like me?
Or any moderator who could help us by WhatsApp or Skype?
The more I read, the less I know how to do it.
thank you and greetings.
Pochoto2
Post by Pochoto2 »
Toonz wrote: Sat Aug 31, 2024 7:49 pm The only option to get the subscription features back is to root your Toon (see guides elsewhere).
Thanks Toonz!
I was in the same situation. TOON 1 from Spain (Viesgo VPN) with v6.3.60. I followed the Root-A-Toon-USB-Stick procedure......and IT WORKS!!!!
As the TOON was already activated, i directly went to the root procedure (make sure you have the TOON connected via WiFi to the ToonRouter SSID and your computer connected to internet via ethernet cable!)
I run the "sudo bash root/toon test" to test the connection. Following the instruction, after rebooting the TOON i got this message and some cmessages appeared in TOON GUI (check you get this same message and you see the messages in your TOON GUI, otherwise the root procedure will not work):
We have connection
Do not touch the screen of your Toon
Just wait and look at your Toon to see the GUI restart
### Reached End Of Job ###
Then i directly tried to root it, so i run "sudo bash root/toon root". I received these messages in Kalix:
The Toon from 10.42.0.224 is connecting to servicecenter IP: 172.18.0.1
GET /device-token-service/device/token?scope=openid%20uid%20agreements%20externalCustomerReference%20organisation HTTP/1.1
Host: feed.hae.int:31080
Accept: */*
This is not a update request.
Accept: */*
Accept: */*
PUT /schedule-service/device/qba-900-3125/schedules/467e040c-113f-46e1-8e75-d01a4680b837 HTTP/1.1
Host: 172.18.0.1:31080
Accept: */*
sender: display
Content-Type: application/json
Content-Length: 2335
Expect: 100-continue
{"id":"467e040c-113f-46e1-8e75-d01a4680b837","weeklyEntries":[{"secondsSinceMondayMidnight":558000,"preset":{"id":"247872a9-c629-44e6-8c74-72141085253a","name":"home"}},{"secondsSinceMondayMidnight":583200,"preset":{"id":"26a833fb-5d91-443f-ac61-e43fe9a28bff","name":"comfort"}},{"secondsSinceMondayMidnight":601200,"preset":{"id":"f2820969-c349-44ee-accd-4219bf60b845","name":"sleep"}},{"secondsSinceMondayMidnight":28800,"preset":{"id":"3d636315-0301-4645-b5d8-6d9dc9af6b71","name":"away"}},{"secondsSinceMondayMidnight":64800,"preset":{"id":"26a833fb-5d91-443f-ac61-e43fe9a28bff","name":"comfort"}},{"secondsSinceMondayMidnight":82800,"preset":{"id":"f2820969-c349-44ee-accd-4219bf60b845","name":"sleep"}},{"secondsSinceMondayMidnight":115200,"preset":{"id":"3d636315-0301-4645-b5d8-6d9dc9af6b71","name":"away"}},{"secondsSinceMondayMidnight":151200,"preset":{"id":"26a833fb-5d91-443f-ac61-e43fe9a28bff","name":"comfort"}},{"secondsSinceMondayMidnight":169200,"preset":{"id":"f2820969-c349-44ee-accd-4219bf60b845","name":"sleep"}},{"secondsSinceMondayMidnight":201600,"preset":{"id":"3d636315-0301-4645-b5d8-6d9dc9af6b71","name":"away"}},{"secondsSinceMondayMidnight":237600,"preset":{"id":"26a833fb-5d91-443f-ac61-e43fe9a28bff","name":"comfort"}},{"secondsSinceMondayMidnight":255600,"preset":{"id":"f2820969-c349-44ee-accd-4219bf60b845","name":"sleep"}},{"secondsSinceMondayMidnight":288000,"preset":{"id":"3d636315-0301-4645-b5d8-6d9dc9af6b71","name":"away"}},{"secondsSinceMondayMidnight":324000,"preset":{"id":"26a833fb-5d91-443f-ac61-e43fe9a28bff","name":"comfort"}},{"secondsSinceMondayMidnight":342000,"preset":{"id":"f2820969-c349-44ee-accd-4219bf60b845","name":"sleep"}},{"secondsSinceMondayMidnight":374400,"preset":{"id":"3d636315-0301-4645-b5d8-6d9dc9af6b71","name":"away"}},{"secondsSinceMondayMidnight":410400,"preset":{"id":"26a833fb-5d91-443f-ac61-e43fe9a28bff","name":"comfort"}},{"secondsSinceMondayMidnight":428400,"preset":{"id":"f2820969-c349-44ee-accd-4219bf60b845","name":"sleep"}},{"secondsSinceMondayMidnight":471600,"preset":{"id":"247872a9-c629-44e6-8c74-72141085253a","name":"home"}},{"secondsSinceMondayMidnight":496800,"preset":{"id":"26a833fb-5d91-443f-ac61-e43fe9a28bff","name":"comfort"}},{"secondsSinceMondayMidnight":514800,"preset":{"id":"f2820969-c349-44ee-accd-4219bf60b845","name":"sleep"}}]}-------------------------------------------------------
Accept: */*
Accept: */*
Accept: */*
But the upgrade button didn't appear in TOON in the menu Home->Configuration->Software->Software Version
So i directly left the PC working, and after a while (10minutes later), i checked again TOON and i could see the "Upgrade" button just to the right of the Software version. I clicked on it and TOON was rooted!!!:
Thanks for the support you bring!
Great !! I think it is about time to work on a Spanish translation of the ToonStore ;-)
Pochoto2
Post by Pochoto2 »
Toonz wrote: Fri Oct 04, 2024 3:08 pm Great !! I think it is about time to work on a Spanish translation of the ToonStore ;-)
It will be great!! Is there any option to change it to english??
Now i'm trying to add the energy meter (qubino).It worked in the past, and i could see the energy consumption every 5-10seconds, but the last oficial software upgrade lost the option in the menu to add this kind of hw...
Mramos1985
Post by Mramos1985 »
Thx Pochoto2 for your help, Toon rooted.
Now, I wish use toon from my mobile phone... Any idea?
And about the Toon Store, any app interesting to install???
BR
oepi-loepi
Post by oepi-loepi »
You can set a username and password in the menu TSC-mobile login.
After that you can go to the ipadress of the toon followed by /mobile like xxx.xxx.xxx.xxx/mobile. This works on the same wifi network. For external access you can set a port forward in your router and after that the toon is usable by the extarnal (public) ip adres followed by /mobile.
Mramos1985
INCREDIBLE HELP from @Pochoto2.
Thx so much for your patience and your kindly help...
My Toon seems a new one... New features and now in Spanish!!!! Great job!!
Rufy
Post by Rufy »
Hola
Hace varios meses me ha dejado de funcionar el termostato inteligente Toon de Repsol, meses he puesto en contacto con ellos pero me dicen que no pueden hacer nada y que ya ese aparato se ha quedado como termostato analógico aunque tenga pantalla y tenga conexión establecida a internet. Ahora Toon te envía a una APP neerlandesa. Estoy seguro de que esta table puede liberarse para poder usarla como antes para poder manejar domoticamente la temperatura, saber el consumo eléctrico a tiempo real etc, podrían ayudarme por favor?
Mil gracias por adelantado!
EDIT by Toonz: Please post in English, our knowledge of Spanish is limited to google translate:
"Hello
Several months ago the Repsol Toon smart thermostat stopped working, months ago I contacted them but they told me that they could not do anything and that this device had already remained as an analogue thermostat even though it had a screen and had an established internet connection. Now Toon sends you to a Dutch APP. I am sure that this table can be released to be able to use it as before to be able to manage the temperature homemotically, know the electricity consumption in real time etc, could you help me please?
Thank you so much in advance!"
If I understand you correctly you want to control Toon with your mobile phone?
Since the Toon subscription services stopped in Spain your only solution is to root the Toon to enable (most) subscription features again
Return to “Toon Rooting”
