When connected, the pulse switch switches on the light as long as I keep it pressed.. The white (split) cable going down is connected to a lamp
Fibaro: S1 goes into the switch
Fibaro: Q1 goes to the lamp
Fibaro: IN is connected with L
Fibaro: L & N to 230v
Switch: other connection to L
It feels like I have connected the switch the wrong way
Fibaro parameter 14 (0=momentary switch, 1=toggle switch) have been tested with both 0 and 1. Same result.
Any idea?
Cheers
Dirk
