Rooted Toon Fibaro HC3
Ruud
Post by Ruud »
Has anyone already linked the rooted Toon to a Fibaro Hc3 via Quick apps or Lua?
Ruud (rualblas)
TerrorSource
Re: Rooted Toon Fibaro HC3
Post by TerrorSource »
Doesn’t the Virtual Device plugin for HC2 also works on HC3? Have you checked that out before asking? ;)
Ruud
Post by Ruud »
Of course I checked it :lol:
Vd no longer works in HC3 and has been replaced by quick apps and is not a conversion
Ruud (rualblas)
TerrorSource
Maybe you can check the Domoticz topic in "External Control". The manual used DzVents(Domoticz own script language) but also uses parts of LUA.
On the Domoticz forum are also parts LUA-script to control the Toon.
EDIT: here: https://www.domoticz.com/forum/viewtopic.php?t=11421
samll
Post by samll »
Never heard of it
any benefits?
oops, didn't mean to edit
SDeath
Post by SDeath »
Yes I have!
I got my HC3 to replace my HC2 last week, and been busy converting everything manually, I have lot's of LUA in my HC.
And also converted the VD by fkruis to a HC3 QuickApp.
I have them attached to this post.
Both QuickApps will start updating within 1 minute and keep doing so every minute automatically.
All functions work like before.
Just change the IP address for each QuickApp in the QuickApp Variables to the IP of your Toon and it should work:
Toon_Connect_3.1.fqa.zip
Bug fix for local QuickApp variable change
(3.02 KiB) Downloaded 543 times
Toon_Data_3.0_VAR.fqa.zip
(2.11 KiB) Downloaded 507 times
Toon1 running firmware 5.33.9 (rooted)
SDeath
Post by SDeath »
Updated my previous post to fix a bug.
Please download 3.1 version of the Connect app.
Ruud
Post by Ruud »
Toonconnect werkt prima, maar Toondata blijft leeg geen info.
Alleen ip aanpassen toch?
Groet Ruud
Ruud (rualblas)
antoncrx
Post by antoncrx »
Goodmorning
I have the same issue, toonconnect works perfect but toondata gives an error
[26.09.2022] [10:53:01] [ERROR] [QUICKAPP86]: QuickApp crashed
[26.09.2022] [10:53:01] [ERROR] [QUICKAPP86]: main.lua:34: attempt to concatenate a nil value (global 'ElecProduction')
thanks a lot for the help
Anton
