X10 Security stuff
Kroonen
X10 Security stuff
Post by Kroonen »
I want to have some security modules in X10. Can you just by for example a some detector, and you recieve the signals on a cm11g interface, or do you need more. I just want that all my lamps go on when it detects smoke. If a cm11g doesn't a rfxcom receiver will work?
greetz Richard
b_weijenberg
X10 Security stuff
Post by b_weijenberg »
Richard,
The CM11 is a device to let your PC talk with X10 devices on the power line.
The X10 security sensors transmit RF signals that can be received by the RFXCOM receiver.
See this picture:
http://www.rfxcom.com/images/x10appl.jpg
X10 Security stuff
I have 2 (more to come) Smoke detectors online, received by a RFXCOM receiver. I use the Marmitek SD90 Smoke detectors.
You can see them at http://www.hekkers.net/test/Devices_Main.aspx
Robert
