Reset RFXCom Lan receiver
abl
Post by abl »
Just installed a new modem/router. After installation I'm not able anymore to reach my RFXCom Lan receiver. Looking at the ports (green and orange lights at the back) of the RFXCom device it is connected to the network. The problem is that I can't remember the IP address (I pinged a few numbers but these didn't work).
Is there anyway to reset my RFXCom receiver so that I can connect to the receiver?
Re: Reset RFXCom Lan receiver
Did you try to start DeviceInstaller (delivered on the RFXCOM CD)
abl
Post by abl »
Just checked but couldn't find my cd.
However I've backed up all my installer cd's/dvd's.
In the attached picture I added a screenshot of the RFXCom directory, but couldn't locate the specific file you mentioned...
rfxcom directory.jpg (111.85 KiB) Viewed 4907 times
b_weijenberg
Post by b_weijenberg »
DeviceInstaller is Di32DL_4.2.0.4_Web.exe.
If you enable Autostart on the CD drive or open index.htm you will see the CD contacts with links.
The latest versiuons of DeviceInstaller and CPR are available at:
http://ltxfaq.custhelp.com/app/answers/detail/a_id/644
http://ltxfaq.custhelp.com/app/answers/detail/a_id/928
abl
Post by abl »
Bart, thanks very much. I'm now able again to login to my RXFCom receiver. For your information; the links you posted are inactive...
drmacchi
Post by drmacchi »
I tried the links , on my pc they work. (momentary failure?)
