I'm busy replacing my MIDON LOG08 1-wire controller for the Poseidon 1250 controller which will control my Temperature and humidity sensors.
Advantage that it has a Lan controller and a webserver and supports XML.
I'm busy connection and replacing existing 1-wire with this controller.
It also has 3 digital inputs.
check it out here http://www.bwired.nl:93/
need to place all the sensors yet so they now have all the same readings [:)]
Keep you posted on this project
extra Info:
Sensors can be connected to the Poseidon model 1250 unit via two busses or you connect directly senor's contacts. The device measures values of connected sensors, the user can access the data over specialized protocols or web browser.
Poseidon can be integrated into NMS (Network Monitoring System), or used with the PD trigger software which simply alerts of a critical situation by sending an SMS message. As an alarm response, this software can close a relay (via network) that controls e.g. light signaling or alarm horn.
Industrial bus (RS485): up to 31 sensors, up to 1 000m
3 Digital inputs: connect relay dry contact directly
IT bus (1-Wire): up to 10 low cost probes, RJ11 wiring
Sensor value out of range: sending Email or SNMP Trap to several recipients.
http://www.hw-group.com/products/poseid ... 50_en.html
Pieter Knuvers
