Visonic and homeseer
Moderators: Rene, Willem4ever
bartbakels
Post by bartbakels »
Dear all,
I am thinking about replacing my alarmsystem wit visonic securitysystems. However i want to use the sensors in homeseer and have the abbility to arm and disarm from homeseer.
What are my options and what do. Need?
I read about the waakzaamwonen interface and plugin, but is it also possible to inpteace the powerlink interface with a plugin or maybe directly via rs232? And are my wishes possible and what do i need t do this.
Thanks for helping
Bart
(ON ESXI )on NUC
uAlex73
Re: Visonic and homeseer
Post by uAlex73 »
I don't think such plugin for direct Visonic exists, you can only use the Alphatronics interface (or the RFXCom one). NOTE: When you buy a Visonic, you need to buy a PowerMax, because a PowerMaster (G2) doesn't work with Alphatronics/RFXCom.
bartbakels
Thank alex
Is it also possible to arm and disarm the powermax with this interface?
Thanks
(ON ESXI )on NUC
olof
Post by olof »
I have Visonic and Homeseer via RFXCOM. But I only capture the Visonic sensor information into Homeseer. I don't control Visonic via Homeseer.
I seem to recall it was possible or at least many attempts were made by some the experts in this forum.
I'm afraid you will have to read all the sticky postings in the VIsonic-Homeseer section. I think it is buried in there somewhere....
Olof
Look here: http://www.domoticaforum.eu/viewforum.php?f=72&start=0
Based on http://www.domoticaforum.eu/viewtopic.php?f=68&t=6581 you should be able to control a Visonic Powermax.
I've even made a small interface on my smartphone for it:
2013-06-27 21.07.11.png (67.33 KiB) Viewed 7607 times
bartbakels
My visionic has arrived (thnx TANE). Now it time to hookup the serial connection (hopefully direct on the 10 pins header) and start playing with the programmer software and the descibed protocol. However there is also a homesee plugin made by rene. But cant get in contact with him :(
thanks for your support
Bart
(ON ESXI )on NUC
