stretch no connection whith cicle+ after upgrade frmw
Post by Harry »
my stretch has had an firmware upgrade, after upgrade it could not connecting to the circle+.
after that problem i have reseted the circle+. it did not help.
now i read in the manual that the circle+ may not be reseted :oops: what should i do to get the connection back?
Phoenix
Re: stretch no connection whith cicle+ after upgrade frmw
Post by Phoenix »
Hi Harry,
Wich version of the firmware has been installed?
Huisautomatisering - Domotica - Elektronica - IT consulting - Software ontwikkeling - 3D printing - Maatwerk
Website: domoticx.nl / Webshop: domoticx.nl/webwinkel / Knowledge Center: http://domoticx.com
Post by Harry »
the 2.1.8 version is installed
Phoenix
Post by Phoenix »
Hmmm i have some stretches with 2.1.8 no problems here!
Whats does http://192.168.x.x/core/networks say?
Is there a "network_coordinator id" line in the xml output?
Post by Harry »
i have called the helpdesk today,... they told me that the circle+ must be matche to the stretch.
i did reset the cicle+ and that's coursing the problem.... the stretch cannot pair to the cicle+ by it's self :(
this only can be done by plugwise,...so i have to sent the hardware to plugwise to fix this, they do this without charging costs :mrgreen:
lesson to learn ... read first the manual before resseting something :wink:
RdP
Post by RdP »
Harry wrote:the 2.1.8 version is installed
Can the Stretch users on this forum confirm that firmware version 2.1.8 is the firmware which is publicly available now (So not being een beta user etc.. to get it)
Thanks,
Post by Harry »
i am not a Beta user
dorenberg
Post by dorenberg »
I have the same problem and contacted plugwise. They offered me 2 options.
1. Open the stretch and remove the usb stick and re-connect the circle+ via source.
2. Send the stretch to plugwise.
After doing option 1, the circle+ was connected via source. Putting the stick back and rebooting the stretch..... the same problem again.
dorenberg
Post by dorenberg »
small update on last remark. Everything up and running with option 1
Return to “Plugwise Forum”
