Toon app: Afvalwijzer
oepi-loepi
Re: Toon app: Afvalwijzer
Post by oepi-loepi »
Dat is toch al verwerker 41 ?
4nuts
Post by 4nuts »
Hi , It looks like that afvalwijzer.nl has made changes maybe ?
I use waste collector 1 and it doesn't show any waste dates anymore.
Great app ! we use it on daily basis.
flamingbob
Post by flamingbob »
After updating the toon2 seems provider 16 also stopped working. just a blank title. Maybe they changed something again?
4nuts
Post by 4nuts »
4nuts wrote: Sun Apr 24, 2022 1:32 pm Hi , It looks like that afvalwijzer.nl has made changes maybe ?
Hmm it solved itself :) now all dates availbile again.
whizzz63
Post by whizzz63 »
Is het mogelijk RWM toe te voegen?
Bruce the boss
Post by Bruce the boss »
4nuts wrote: Sun Apr 24, 2022 5:25 pm
Mmmm, I do have the same problem since yesterday and until now it didn't solve itself. I restarted the Toon already but still no dates. What could I do to solve this problem?
4nuts
Post by 4nuts »
Bruce the boss wrote: Mon Apr 25, 2022 7:15 am
This morning it is empty again, going into the menu and back normally restore the dates, but now it stays empty again.
Bruce the boss
We have to wait for Oepi-loepi ....... :D
I am a week on leave, will be able to look into this mid next week...
Bruce the boss
Bij mij werkt het nu weer dus denk dat het aan hun kant lag.
oepi-loepi
Guess it is working again. Maybe some error at the afvalwijzer server.
4nuts
Post by 4nuts »
oepi-loepi wrote: Mon Apr 25, 2022 6:42 pm Guess it is working again. Maybe some error at the afvalwijzer server.
Yes it is working again. :)
a3vd
Post by a3vd »
Hoi sinds deze week trotse bezitter van een rooted toon 2 na de toon 1 tijden gehad te hebben, alles geupdate en geinstalleerd alleen nog problemen met de afvalkalender hij blijft helaas leeg. :shock:
Heb dacht ik alle stappen goed doorlopen :
-Update gedraaid (versie 5.5 afvalkalender)
- /mnt/data/tsc/wastecollection.userSettings.json gewijzigd {"Afvalverwerker":"16","CreateICS":"Yes","CustomIcons":"No","DisplayIconVanafUur":18,"ExtraDatumsFile":"","ExtraDatumsIconsFolder":"","Gemeente":"Noordwijk","Huisnummer":"13","ICSUrl":"https://wasteapi2.ximmio.com/api/CallIc ... Icon":"Yes"}
- Onze afvalverwerker is Meerlanden nr 16
Wat mij opviel bij de changelog fix 4.63 dat er stond :
- The part should now look like "ICSUrl":"https://wasteprod2api.ximmio.com/api......"
- Ik krijg echter bij kopieren kalender "https://wasteapi2.ximmio.com/api/CallIc ... 4490-ba9d-
Kan iemand mij helpen met de mogelijke oplossing TNXS ! :mrgreen:
Je hebt geen goede link naar een kalender.
Login met je postcode / huisnummer bij meerlanden.nl
Als de kalender verschijnt zie je rechtsboven de kalender de optie "zet in agenda'.
Druk op die optie en druk vervolgens op de knop 'Kopieer' . Dan krijg je de juiste link.
a3vd
Post by a3vd »
Als ik inlog bij meerlanden krijg ik toch echt alleen deze link bij zet in agenda en kopieer, mogelijk is er toch iets veanderd bij meerlanden ?
