Plugwise Smile P1
Re: Plugwise Smile P1
Post by Harry »
i am thinking of fitting an smile to my system, course there is fitted a smartmeter today in our house.
and my old logging system (rfxcom) is not possible anymore.
i like to have my electr and gas counters in homeseer,... can that be done?
with an smile trough sourse into homeseer?
i don't want to use the plugwise phone app !!
i like only to have the data local, and not on a portal from plugwise.
There are other, cheaper (and gauranteed private), better ways.
Arduino, Raspberry, you name it and it's doable, just search the web (and this forum).
I think with a Raspberry Pi and the MQTT Plugin (http://www.domoticaforum.eu/viewforum.php?f=74) you've also got the link with Homeseer...
RdP
Post by RdP »
Harry wrote: i like to have my electr and gas counters in homeseer,... can that be done?
Use the homeseer plugwise plug-in and you can see these info. The plugin works together with the plugwise source software so that's pre-requisite.
/Rien
Post by Harry »
i already use the plugwise plugin on my homeseer , this works fine and stable for i think a few years now.
i not sure when i buy an smile p1 , that i can read it out on source?
i don't want to registrate it to a portal on the internet or so?
RdP
Post by RdP »
See image !!!
Post by Harry »
@ Rien
i have a two tarief counter, and becourse we have solarpanels and dellifering back.
a total of 4 power counters can that be done ?
Post by Harry »
i have now fitted a smile to the smartmeter,.. but how do i get the counters in source?
i can't find that in the manual,....
is there something special i have to do to get the power and gas counters in source :( :?:
labium
Post by labium »
you have to run the config of source where you add your plugs and check a checkbox there which says you have a smile.
Post by Harry »
I have lokkt for the checkbox , can't find it....
is this the place where the checkbox has to be?
Akatar
Post by Akatar »
nope, on you're first screen
Post by Harry »
oke thanks got it,.. :D .did not now there was a configuration wizzard :(
got the 2 divices, gas and power.
it seems the powercounter do's not split the 4 seperate counters (low,hight and production Low,and high).
oke thanks for the help on this.
Post by Harry »
i bought my smile from annother plugwise user, and i have now his historic data in my system .
how can i delete the data from the previous user?
Rutger
Post by Rutger »
Every week on the same day and at the same timestamp (after last restart), the Smile hangs and can't report any data. Even I can't open the html pages itself.
Only solve is to restart the device.
Smile fw version: 1.2.14
Anyone familiair with this problem?
btw: I don't use Source, only HS plugin from Rien and Smilereader from Phoenix, but both has nothing to do with the problem described above.
RdP
Post by RdP »
Rutger wrote:Every week on the same day and at the same timestamp (after last restart), the Smile hangs and can't report any data. Even I can't open the html pages itself.
Firmware version 2.x should be available by now. If not, you can contact plugwise and they put you on the beta list
I run 2.x versions for months now, without any issues.
/rien
Rutger
Post by Rutger »
I checked it already in the PW app, but no update available.
I'll contact PW for the beta version. thnx.
Return to “Plugwise Forum”
