Plugwise Smile P1
Re: Plugwise Smile P1
i am thinking of fitting an smile to my system, course there is fitted a smartmeter today in our house.
and my old logging system (rfxcom) is not possible anymore.
i like to have my electr and gas counters in homeseer,... can that be done?
with an smile trough sourse into homeseer?
i don't want to use the plugwise phone app !!
i like only to have the data local, and not on a portal from plugwise.
There are other, cheaper (and gauranteed private), better ways.
Arduino, Raspberry, you name it and it's doable, just search the web (and this forum).
I think with a Raspberry Pi and the MQTT Plugin (http://www.domoticaforum.eu/viewforum.php?f=74) you've also got the link with Homeseer...
Use the homeseer plugwise plug-in and you can see these info. The plugin works together with the plugwise source software so that's pre-requisite.Harry wrote: i like to have my electr and gas counters in homeseer,... can that be done?
/Rien
i already use the plugwise plugin on my homeseer , this works fine and stable for i think a few years now.
i not sure when i buy an smile p1 , that i can read it out on source?
i don't want to registrate it to a portal on the internet or so?
See image !!!
- 2013-05-26_1243.png (19.38 KiB) Viewed 15122 times
@ Rien
i have a two tarief counter, and becourse we have solarpanels and dellifering back.
a total of 4 power counters can that be done ?
i have now fitted a smile to the smartmeter,.. but how do i get the counters in source?
i can't find that in the manual,....
is there something special i have to do to get the power and gas counters in source
you have to run the config of source where you add your plugs and check a checkbox there which says you have a smile.
I have lokkt for the checkbox , can't find it....
is this the place where the checkbox has to be?
nope, on you're first screen
oke thanks got it,..
.did not now there was a configuration wizzard
got the 2 divices, gas and power.
it seems the powercounter do's not split the 4 seperate counters (low,hight and production Low,and high).
oke thanks for the help on this.
i bought my smile from annother plugwise user, and i have now his historic data in my system .
how can i delete the data from the previous user?
Every week on the same day and at the same timestamp (after last restart), the Smile hangs and can't report any data. Even I can't open the html pages itself.
Only solve is to restart the device.
Smile fw version: 1.2.14
Anyone familiair with this problem?
btw: I don't use Source, only HS plugin from Rien and Smilereader from Phoenix, but both has nothing to do with the problem described above.
Firmware version 2.x should be available by now. If not, you can contact plugwise and they put you on the beta listRutger wrote:Every week on the same day and at the same timestamp (after last restart), the Smile hangs and can't report any data. Even I can't open the html pages itself.
I run 2.x versions for months now, without any issues.
/rien
I checked it already in the PW app, but no update available.
I'll contact PW for the beta version. thnx.
