I bought two powernodes (6 ports) Nuon aka Greenwave.
They have different firmware versions and the settings are different as well in openzwave control panel (see attached photo).
The problem I have is that I can't reset the values like the other powernode and also a lot of unknowns are there
Is there a way to put a new firmware on there?
Bjorn
GreenWave Unknown (powernode)
- Capture.JPG (69.45 KiB) Viewed 12171 times
Re: GreenWave Unknown (powernode)
140 views..... no one?
You cannot update the firmware of the Greenwave Powernodes. Why would you want that ?
You can lookup how to configure them elsewere in this forum. The most important setting is parameter 1 the no communication timeout in minutes. If you do not poll the device before this timer times out, the big green light around the mains switch starts flashing.
Gert
Gert
I understand but why do I have no totals with node8 while I have them with node7.
Also I have different Library/ Protocol and Application versions between node7 and node8
Also I can not read the configuration out of node8.
I will reset the device maybe that will help
Do you have a copy of your zwcfg*xml? Then I can compare it with my powernodes (i got both 1 and 6 port versions).
I'm using domoticz and I assume it is in the Config directory
Attached the file
Bjorn
Attached the file
Bjorn
- zwcfg_0x0161d745.zip
- (3.43 KiB) Downloaded 537 times
Hoi,
Heb het al opgelost
Aan de hand van http://www.domotiga.nl/projects/domotig ... _OpenZWave (Unknown device in Z-Wave Commander):
<Manufacturer id="0099" name="GreenWave">
<Product type="0002" id="0002" name="PowerNode 1 port" config="greenwave/powernode1.xml"/>
<Product type="0003" id="0004" name="PowerNode 6 port" config="greenwave/powernode6.xml"/>
</Manufacturer>
is nu:
<Product type="0003" id="0006" name="PowerNode 6 port" config="greenwave/powernode6.xml"/>
</Manufacturer>
Heb het al opgelost
</Manufacturer>
is nu:
</Manufacturer>
Can you open a ticket with open-zwave, that they add this combination to their xml file? Else it is lost during every upgrade ... and you are helping other people too.
https://code.google.com/p/open-zwave/issues/list
And click on "New issue"
