Toon not booting after failed update
MadDemonoide
Post by MadDemonoide »
Hey.
I tried doing a software update, and the power fell out during the update.
I can access SSH, and the screen is stuck at the T logo.
I tried using the update script, but it cannot seem to connect to the vpn. The keys are in the vpn folder.
What can i do?
Thanks
TerrorSource
Re: Toon not booting after failed update
Post by TerrorSource »
can you try the update script as followed:
sh update-rooted.sh -v 4.19.10
and tell us wat happens :)
So it is booting.
You can test whether vpn is started by typing
ps | grep vpn
If that gives no output (or nothing useful) you can start vpn manually by copying the command part of the openvpn line from /etc/inittab into the ssh console and run it.
MadDemonoide
Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you :)
MadDemonoide
As far as I can see it is running.
I see the line and the conf file defined there.
marcelr wrote:So it is booting.
ps | grep vpn
TerrorSource
MadDemonoide wrote:Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you :)
Just keep trying a few times. had that once before too.
Also, check the /etc/inittab if it's not empty.
MadDemonoide
I tried a few times now. Nothing changes.
The inittab is not empty. The openvpn item is there. Uncommented.
Thank you :)
In that case, you should be able to ping feed.hae.int, and get a response.
MadDemonoide
marcelr wrote:In that case, you should be able to ping feed.hae.int, and get a response.
I’m not getting a response from that URL.
try
ping 8.8.8.8
(google) then.
If that doesn't give a response, you don't have a working connection to the outside world.
MadDemonoide
When I try to manually start the VPN, I get the following:
Socket bind failed on local address. [AF_ INET]127.0.0.1:8000 Address already in use.
MadDemonoide
marcelr wrote:try
ping 8.8.8.8
(google) then.
I tried google. I get a nice ping back.
Maybe you should edit inittab to not start openvpn, then kill it, and let the script do it for you.
Post by TheHogNL »
I think you have a very old version of Toon firmware which doesn't update the /etc/hosts file properly (your feed.hae.int entry in your hosts file doesn't match with the routing table)
Try to remove the "feed.hae.int" line from the /etc/hosts file and restart the Toon and the script again.
MadDemonoide
marcelr wrote:Maybe you should edit inittab to not start openvpn, then kill it, and let the script do it for you.
I can start the VPN manually, but it still does not update.
It also shows up @ the top command as a process.
