Toon not booting after failed update
- Starting Member
Hey.
I tried doing a software update, and the power fell out during the update.
I can access SSH, and the screen is stuck at the T logo.
I tried using the update script, but it cannot seem to connect to the vpn. The keys are in the vpn folder.
What can i do?
Thanks
What can i do?
Thanks
- Administrator
Re: Toon not booting after failed update
can you try the update script as followed:
sh update-rooted.sh -v 4.19.10
and tell us wat happens
So it is booting.
You can test whether vpn is started by typing
If that gives no output (or nothing useful) you can start vpn manually by copying the command part of the openvpn line from /etc/inittab into the ssh console and run it.
ps | grep vpn
- Starting Member
Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you
Thank you
- F18B8768-260E-4BB2-AC4A-DBF04CABFC95.jpeg (125.34 KiB) Viewed 9192 times
- Starting Member
As far as I can see it is running.
I see the line and the conf file defined there.
marcelr wrote:So it is booting.
If that gives no output (or nothing useful) you can start vpn manually by copying the command part of the openvpn line from /etc/inittab into the ssh console and run it.Code: Select all
ps | grep vpn
- Administrator
Just keep trying a few times. had that once before too.MadDemonoide wrote:Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you
Also, check the /etc/inittab if it's not empty.
- Starting Member
I tried a few times now. Nothing changes.
The inittab is not empty. The openvpn item is there. Uncommented.
TerrorSource wrote:Just keep trying a few times. had that once before too.MadDemonoide wrote:Hey. With the forcing it is still waiting for VPN to be alive. See the screenshot.
Thank you
In that case, you should be able to ping feed.hae.int, and get a response.
- Starting Member
I’m not getting a response from that URL.marcelr wrote:In that case, you should be able to ping feed.hae.int, and get a response.
try
(google) then.
If that doesn't give a response, you don't have a working connection to the outside world.
ping 8.8.8.8
- Starting Member
When I try to manually start the VPN, I get the following:marcelr wrote:In that case, you should be able to ping feed.hae.int, and get a response.
Socket bind failed on local address. [AF_ INET]127.0.0.1:8000 Address already in use.
- Starting Member
I tried google. I get a nice ping back.marcelr wrote:try(google) then.Code: Select all
ping 8.8.8.8
Maybe you should edit inittab to not start openvpn, then kill it, and let the script do it for you.
I think you have a very old version of Toon firmware which doesn't update the /etc/hosts file properly (your feed.hae.int entry in your hosts file doesn't match with the routing table)
Try to remove the "feed.hae.int" line from the /etc/hosts file and restart the Toon and the script again.
- Starting Member
I can start the VPN manually, but it still does not update.marcelr wrote:Maybe you should edit inittab to not start openvpn, then kill it, and let the script do it for you.
It also shows up @ the top command as a process.
